(Yet another) bi-wire question
TN_Polk_Lover
TN_Polk_Lover Posts: 243
I try to do as much reading and research as I can before asking a question that I'm sure has been answered many times, but . . .
I think that I know the basics of bi-wiring and the difference between bi-wiring and bi-amping. However, there is one thing I'm not sure about. To bi-wire, do you have to have an amp with A and B speaker connections? In other words, if you have an amp with only one set of binding posts, can you still connect both sets of speaker cables to the one set of binding posts, even though, at the speaker the 2 sets of speaker wires are connected to 2 sets of binding posts?
To further clarify: If an amp has 2 sets of binding posts (typically labeled A and B), internally are both sets of binding posts just connected in parallel to the amp output stage. (I realize that there may be switches involved in order to cut the "A" on or off, or the "B" on or off.) But, other than the switches, is there any circuitry that makes the 2 sets of output posts special or different?
Thanks, everyone. This is a great forum. I don't post that often even though I've been around quite a few years.
Robert
You are officially in the high-end of the deep-end of the top-end.
Bonus Room Over Garage:
Toshiba 27" CRT TV
Digital Source: Sony DVP-NS3100ES
DVR: Panasonic DMR-ES15
Denon 3806 AV Receiver
- L/R Preamp out to Parasound HCA-1200 Amp
Polk RTi70's, CSi40 Center, RTi38 Side Surrounds, RTi38 Back Surrounds
Living Room: (2ch only)
TV: Sony KV20-FV12
DVD Player: Sony DVP-NS715P
Yamaha R9 Receiver Polk RTi38's
Post edited by TN_Polk_Lover on
  • PolkWannabie
    PolkWannabie Posts: 2,763
    edited February 2007
    On the Sunfire amps for example there are typically what are called output Voltage and Current Source terminals ... The Voltage source is at zero ohms like most sand amps ... The Current source is at ~1 ohm and produces a warmer, tube like sound. One could then for example biwire speakers with the current source ( warmer ) outputs going to the tweets and the voltage source going to the rest.
  • just_visiting
    just_visiting Posts: 40
    Yes, twist the 2 bare cables together to form one single bare wire and connect it to a receiver or an amp.
    Display: Sony XBR3 46"
    Pre/Pro: Marantz AV7005
    Amplifiers: Anthem MCA20 / Anthem MCA30
    CD: Pioneer Elite PD59 / Sony XA20ES / Denon 755AE
    DVD: Denon 3930CI
    BD: Pioneer Elite 05FD
    Sat: Bell TV 9241HD
    Game: Sony PS3 60GB
    Media Streamer: WDTV Live Hub
    Power Console: Panamax 5300PM
    Speakers: Paradigm Reference Studio v.3
    Subwoofer: SVS 16-46PC+
    Preamp: Parasound P3
    Amplifier: BAT VK60 Tube
    Sacd: Sony 777ES
    Power Console: Ultralink PGX-500
    Speakers: Paradigm Reference Studio 20 v.5
  • pblanc
    pblanc Posts: 261
    Or you can get a fancy, and expensive, set of four conducter biwire speaker wires which looks a bit neater.
