popped Capacitor
Hirobo
Hello
I have a pair of RM3300SAT Speakers, which have a blown capacitor. I was wondering if someone could tell me what te replacement capacitor would be, by looking at the picture.
Mike
Mike
Post edited by Hirobo on
From that pic - not without a schematic. I would say it is an electrolytic though.
Get a magnifieing glass the specs are right there on the side of the cap. Get the type and call up Solen:cool: " He who dies with the most equipment wins Right ? "
Denon 3300 Adcom 535 BBe w/sub out 1 pr 4.6s 2 pr of 4 jrs Recent additions Samsung Lns-4095D LCD, Samsung hd-960 DVD, Monster HT-5000 Power center,HPSA-1000 18" sealed DiY home sub.:D
Black Laquer 1.2tl's w/ upgraded x-overs and Tweets BI-Amped with 2 Carver tfm-35's Knukonceptz 10ga cables -
Deadof_knight wrote:Get a magnifieing glass the specs are right there on the side of the cap. Get the type and call up Solen
It says something like 5.8mfd 50v +20 -
The value of your electrolytic cap is 5.8 microfarad, 50 volt, +/- 5% tolerance. I'd recommend you replace it with another electrolytic as the film/foil type caps would be a waste in those speakers. Do you know why it popped?Political Correctness'.........defined
President of Club Polk -
not sure i got these speakers from my friend, and he said that they have never worked. I could buy the capacitor online somewhere i would presume.F1nut wrote:The value of your electrolytic cap is 5.8 microfarad, 50 volt, +/- 20% tolerance. I'd recommend you replace it with another electrolytic as the film/foil type caps would be a waste in those speakers. Do you know why it popped? -
here are the picsanonymouse wrote:Yikes, how did that happen? Can you get a close in picture of the side of the capacitor where the text on it is?
If the speakers where not pushed, then my guess the cap is old where it leaked at little (internal resistance) this caused some heat internal which caused it to burst.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
Disneys right excessive heat kills caps on top of old age and being cheap construction to start with. I had problems with the capacitors in my 3000gt vr4 caps got hot started leaking and then pop goes the engine computer DOh! 400.00 dollars later.:cool: " He who dies with the most equipment wins Right ? "
I would check at Radio Shack first. A little pricey but it is instant and no shipping charges or minimum orders.God shows his love for us in that while we were still sinners, Christ died for us. - Romans 5:8
Take note, from your pictures the cap has a +/- 5% tolerance, not 20%. I seriously doubt RS has one, but any real electronics store will. Probably cost you about $0.50.Political Correctness'.........defined
I don't think so but is a crossover cap polarized? That cap looks like a typical dc cap.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
disneyjoe7 wrote:I don't think so but is a crossover cap polarized?
Nope.Political Correctness'.........defined
F1nut wrote:Take note, from your pictures the cap has a +/- 5% tolerance, not 20%. I seriously doubt RS has one, but any real electronics store will. Probably cost you about $0.50.
I checked at radio shack, they do not carry one that maches this. I'll have to check around -
anonymouse wrote:From those close up pictures, I'm not so sure that cap has popped. It looks like they have hot glued all the caps down to the board, so what looks like gel leaking is really glue. Is that substance at the base of the cap feel like hair gel or is it hard like dried glue from a glue gun?
They have them glued to the pcb board
