Amp Recommendation
PolkFan1
PolkFan1 Posts: 130
edited February 2007 in Speakers
I am looking for an amp for my Rti8's and I mainly listen to music. I also have a PSW12 sub and I will be hooking the amp up to my Yamaha HTR-5740 receiver. My budget is 450 bucks..may go to 500
Post edited by PolkFan1 on
  • MikeC78
    MikeC78 Posts: 2,315
    Check over at the videogon/audiogon.com, Ebay, and keep checking around the classifieds.
    May I ask why you are looking for an amp? I believe you are looking for something to tame those RTi's and adding a seperate amp to that Yammy isn't going to solve your problems. You are still going to get that signature sound from that Yammy, and amplify the brightness even more. I believe your best bet is looking at receivers from H/K which tend to be more laidback sounding and offer you more watts per your dollar which will power the RTi series quit nicely IMHO.
    Mike
  • ben62670
    ben62670 Posts: 15,969
    Mike
    Check Ebay for HK direct. They sell refurbs cheap straight from the factory. Thats what I replacedmy Yami with... then started adding amps... then went to speakers... now I'm doing the wires... , but start with the HK.
    http://stores.ebay.com/Harman-Audio
    This is what I bought. I just use it as a pre amp. Its kinda low on the watts... So if you want to buy a used amp like an Adcom you can save some money on the reciever, or you can buy a higher end reciever, and not buy external amps.
    Ben
  • pearsall001
    pearsall001 Posts: 5,299
    Behringer A500 amps. You can get two brand new for under $500. Run each one bridged mono (500x1) your RTi's will sing.
