Momo MM12 Pair
ATLbumpin
ATLbumpin Posts: 12
edited February 2007 in Car Audio & Electronics
I got two Momo mm12's but need a new amp. What type would be the best for these subs??
Doug
Post edited by ATLbumpin on
  • Joelsbass
    Joelsbass Posts: 637
    what's your price range?
    how much power do they handle (RMS value, peak is meaningless)?
    single or dual voicecoil?
    MacLeod: I guess youre lucky Polk has such lax hiring standards.
    Josh: Damn skippy!
  • ATLbumpin
    ATLbumpin Posts: 12
    I know it handles 500rms but not sure about what voice it is
  • MacLeod
    MacLeod Posts: 14,358
    The old MM12 boxes were SVC. Just look for a good Class D mono amp that makes 800-1000 RMS x1 at 2 ohms.
  • Joelsbass
    again, what's your price range?
    Josh: Damn skippy!
  • exalted512
    exalted512 Posts: 10,734
    dont give those things a watt over 1000...
    -Cody
  • ATLbumpin
    ATLbumpin Posts: 12
    I'm thinking of spending about $100-150 or a lil more
  • ATLbumpin
    ATLbumpin Posts: 12
    Also do I just hook up the wires and thats it?
  • Joelsbass
    you want 1000 watts for 100-150.... probably gonna have to hit the pawn shops... just look for a known brand... and avoid sony...
    Josh: Damn skippy!
  • MacLeod
    Ha! Probably wouldnt even find that at a pawn shop!!! Any amp that "claims" 1000 watts or $150, I wouldnt touch with a 10 foot pole!
  • 1996blackmax
    1996blackmax Posts: 2,436
    You could get close to that with a refurbished Kicker ZX750.1 ...they usually put out a little over 900 watts RMS. They have some Kicker authorized B-stock dealers that you can get them from. They go for around $200 bucks. You could also pick one up used on Ebay.
    Alpine: CDA-7949
    Alpine: PXA-H600
    JL Audio: 10W6v2 (x2)
    KnuKonceptz
    Second Skin
  • Joelsbass
    used you can sometimes find that good of a deal, all depends on the market and if the pawn shop realizes what they have in that particular amp...
    Josh: Damn skippy!
  • ATLbumpin
    ATLbumpin Posts: 12
    Well what about a pyle or a Blitz 1000W Mono Block MOSFET Digital Power Amplifier they only cost $150
  • Joelsbass
    NO
    there's a reason the company is called Pyle... cause that's what they are... blitz is another crappy low end manufacturer...
    Josh: Damn skippy!
  • MacLeod
    If you want a budget amp, Profile is about the best there is.
    Crutchfield.com has them.
  • exalted512
    or DB Drive, but theyre better off running at 1 ohm.
    -Cody
  • ATLbumpin
    ATLbumpin Posts: 12
    Can someone give me a suggestion of an amp for 2 mm12's for like $200?
  • ATLbumpin
    ATLbumpin Posts: 12
    Is a Kicker KX 1200.1 mono with 1400 rms good enough??
  • 1996blackmax
    Already did......
    Alpine: CDA-7949
    Alpine: PXA-H600
    KnuKonceptz
    Second Skin
  • DemonAstroth
    DemonAstroth Posts: 131
    If you can find a used Eclipse 34230, it should be right around 200 dollars (have been following a few on Ebay)... and it will be pretty much perfect.
    Demon
  • Jstas
    Jstas Posts: 14,995
    If you can find some old stock Hifonics Nemesis amps, they had a 750Wx1 and a 900Wx1 amp. You can probably find them used or "old stock" on closeout for less than $200. They are stout and I've used a couple of the Nemesis amps. They are basically the original Zeus series amps without all the bells and whistles.
    Expert Moron Extraordinaire
  • black magic
    black magic Posts: 669
    lol. word. sony has some awesome electronics, but they're amps dont match up to their reputation.
  • Joelsbass
    No sony car electronics is worthwhile, Amps, Headunits, Speakers, none of it... they make a damn good TV though lol...
    so i guess if you want to put a 30" LCD in your trunk sony would probably be the way to go :p
    Josh: Damn skippy!
  • black magic
    two for me, please ;)
  • 1996blackmax
    Their stuff from a few years back was very, very nice.... to bad they went down hill....:(
    Alpine: CDA-7949
    Alpine: PXA-H600
    KnuKonceptz
    Second Skin
