Where do you put yur sub so it sounds the best?
iDoNtKnOe2k1
iDoNtKnOe2k1 Posts: 30
edited October 2001 in Technical/Setup
I got a psw150 and I have the volume and fq. all the way up and i cant seem to hear them when i'm playing some dvds.
My Setup
[SW] [Rr] [T V ]
[CHAIR]
Post edited by iDoNtKnOe2k1 on
  • TrappedUnder Ice
    TrappedUnder Ice Posts: 975
    edited October 2001
    if you can...put the sub on your left side facing out:
    sub>
    this will load the bass on that wall and should increase.. depending on the rest of your system...that sub may not be powerfull enough...
  • RuSsMaN
    RuSsMaN Posts: 17,985
    edited October 2001
    Get a cheap rca cable, or speaker wire long enough to put the sub exactly where you sit. (your sweet spot) Crank it up to your reference level, with material you know well.
    Next, have some cold suds, and literally crawl around the room. This isn't an exact science, but you should put your sub in the spot you crawled to that sounds the best.
    I have had this work fairly well, esp for HT setup, and assuming you are running your sub at a very low freq level <=60 Hz or so.
    If you run your sub 80Hz or higher, I would place it anywhere between the front mains for a good 'blend'. Need more boom? Corner load that beeotch.
    Cheers,
    Russ
  • iDoNtKnOe2k1
    edited October 2001
    Ohkay..thanks for yalls help.
