Help on choosing a amp and subwoofer
bobobob
Hello all,
In my 96 honda civic i'm running a Kenwood KDC-W6527 head unit, some 6x9's MMC690 in the back , and a set of DB6500 in the doors.
I use to have a 5-channel Hifonics zx8000 and a 10" Alpine type-r woofer, and since the last 2 got stolen i am looking for a new setup.
Now i'm looking for a new amp(s) and a subwoofer.
I know the speakers should get about a 100 watt each. And could someone recommend a good subwoofer. Looking for a nice clean sound. It doesnt have to be obnoxious loud, as long as i'm getting a precise, clean, and loud base i'm set. It probably going to be another 10" or even 8" to save some room in my trunk
Thanks for your help!
Post edited by bobobob on
yes i was thinking about getting the db series but i can't find a shop overhere that hass them in stock.... soi don't know how they sound
I have heard the DB subs and they sound OUTSTANDING for the price. How much are you wanting to spend on amp/sub? This will help as to what would be good for your $'s.
DonnyNEWEST RIDE:
2006 Silver Jaguar XKR Coupe with factory BBS 20" and upgraded Brembo Brakes from factory....
Supercharger Pully Upgrade
Air Intake
Mina Exhaust System....
2007 Chevy Tahoe (Daily Driver):
Front Doors POLK sr6500
Amp front JL 450/4
Amp Sub JL 500/1
Sub JL 10w6
(Work Trucks)
2005 Mercury Mountaineer Premier 4.6L V-8
All Stock!!! In the process of changing this.
2002 Chevy Silverado 2500HD 4x4 Crew Cab 6.6L Diesel -
Polkemon wrote:I have heard the DB subs and they sound OUTSTANDING for the price. How much are you wanting to spend on amp/sub? This will help as to what would be good for your $'s.
Donny
Well my last setup was a Hifonics zx8000 and a 10" Alpine type-r, i think that was about $750
I am willing to spend that again since i'm leaning towards getting 2 amps now, i've read somewhere overhere that the mmc690 can even hold 200 watts rms. But finding an amp that produces 4x100+ AND a strong enough fifth channel for a sub is impossible.
So i'm probably looking for 2 amps a 10" sub for around $750! -
bobobob wrote:And could someone recommend a good subwoofer. Looking for a nice clean sound. It doesnt have to be obnoxious loud, as long as i'm getting a precise, clean, and loud base i'm set. It probably going to be another 10" or even 8" to save some room in my trunk
The Soundsplinter RL-i10 sounds like what you are after. I owned one of these in the past and was very satisfied with both the SQ and output that it provided. For that price, I don't think that you'll find anything comparable.
RL-i10:
http://www.soundsplinter.com/rli_ignition_series_8_inch_and_10_inch_diy_subwoofer_drivers.html
http://www.soundsplinter.com/rli_series/rli_10_inch_DIY_car_and_home_subwoofer_driver_information.htmlAlpine: CDA-7949
Alpine: PXA-H600
JL Audio: 10W6v2 (x2)
KnuKonceptz
Second Skin -
1996blackmax, those subs look great and ive read great things about it. Only problem for me is that i'm from europe, and shipping on a sub would probably cost as much the woofer itself....
did you ever heard a Alpine type-r and the RL-i10 ?? -
I've heard the Type-R's, but in a different setup.
I've heard good things about Rainbow subs, and I know you guys have those over there . I do not know how they compare to the Type-R's price wise though. Might be worth listeting to them.
Why don't you want to go with the Alpine sub again? I am assuming you liked them.Alpine: CDA-7949
Alpine: PXA-H600
KnuKonceptz
Second Skin -
yeah i really liked the alpine, but wanted to try something else....
who makes the rainbow subs? -
bobobob wrote:who makes the rainbow subs?
Raindow.
But do you really want a panzy name like Rainbow. I mean, only a real girlie man would run Rainbow speakers.
Those subs sound mighty not straight:D
Well, if you guys do not enjoy listening to music that is produced faithfully, these products may not be for you .........;)Alpine: CDA-7949
Alpine: PXA-H600
KnuKonceptz
Second Skin -
bobobob wrote:yeah i really liked the alpine, but wanted to try something else....
These guys make very high quality products. I am very happy with my German handmade speakers.... have tested very well in Europe and can hang with speakers costing much more.
Here is their site.....
http://car.rainbow-audio.de/home/home.php?lan=2
http://car.rainbow-audio.de/products/introduction.php?lan=2&pro=2Alpine: CDA-7949
Alpine: PXA-H600
KnuKonceptz
Second Skin -
ok, thanks.... i'll have a look see
does anyone has any advice on an amp? the mmc690 and the DB6500 are rated 100W rms so i was looking for a amp with at least 100w p/c @ 4 ohm.. @ 4 channels
the Polk C400.4 is rated at 75 w p/c but i've read a lot of reviews that it is way underestimated, is this so??
And how about the mmc690 crossovers, i dont need these anymore?? -
Polk gives you a birth sheet of the actual RMS since the 75w is a conservative number. Mine said 94w per channel.
hmm ok, that would be good enough, since my last amp gave 55w p/c this would be a big improvement
so these would work with the mentioned speakers right (RMS 100w)? -
The 400.4 would be a great match for those speakers.polkaudio sound quality competitor since 2005
ok, so the 400.4 it will be for the speakers. I'm also thinking about getting the 500.1 for a sub, since those two would look great together.
Now i'm just thinking about which sub to go with..... Alpine type-r, a Soundsplinter, or a Polk
I can listen to a Alpine and a Polk in a shop probably but not the soundsplinter.....Does anyone has some more info about these?
Oh well have to wait a while for the pay check any way, got mail from the insurance company today that they wont give me money for my stolen amp and sub because i never let them know i had these....:o
And also i was thinking about purchasing the amps at www.sonicelectronix.com, does anybody know if this is a reputable company? Since i'm in europe and only for the 400.4 the asking price is $657.- -
Ok to bring this back up, i'm still in the market for another amp. The polk
c400.4 is just a little to pricey over here. And some online shops in the US which i emailed do not ship to europe because of the agreement they signed with polk.
Are there any (affordable $300.-) amps out there that put at least 4x100 watt rms?
Recently a audio store has opened close to me who has brands like Power Acoustik, Boschmann, Earthquake, Soundstream,
some of these brands sound kinda familiar, is there anybody here who has some real experience with some of these brands? -
does cardomain not ship to europe? if not do u have somone u can trust that they can ship to in the US and then have that person ship it to u in europe?2013 Toyota Prius
Audible Physics 3 Way: H6MB, AR3-A, AR2.0
Image Dynamics iDMax 12" D2v4
(2) Alpine PDX-V9 Bridged, Alpine PDX-M12 (500w Mid-Bass, 200w Mid, 200w Tweet, 1200w Sub)
Mosconi 6to8 v8 -
eloplayspolo wrote: »does cardomain not ship to europe? if not do u have somone u can trust that they can ship to in the US and then have that person ship it to u in europe?
yeah that was my second option, just shipping it to a friend of mine in the states, and let him ship it to me...
Anyone have some experience with the brands mentioned above? -
What about MB Quart? I have some MB Quart Q-Series components on layaway and I'm also looking for an SQ sub, but will also need a nice sub amp. Not too worried about the amp right this minute, but wanting a nice SQ sub that will put out some nice deep bass if the situation calls for it.
While I love MB Quart speakers, I never was a big fan of their subs.polkaudio sound quality competitor since 2005
Theres only a few companies that make all products lines top notch. For instance alpine and pioneer have solid product lines. But take a company like polk while I have always be a fan of the way there full range speakers sound. I have never been sold on the subwoofers they are weak will not hold up and don't get that loud. They have sorry xmax always have and the spiders come apart on the momo's after 6 months of use.
Well mine is 3 years old and has been working just fine. Itll reproduce the 18 Hz note on the IASCA disc with authority all day long. And nothing has ever come apart on it despite the fact that the amp Im using is slightly more powerful than its rated for.
Polk subs are excellent.polkaudio sound quality competitor since 2005
to say that pioneer is all good stuff is a joke... their low end stuff is a joke in itself.2013 Toyota Prius
Mosconi 6to8 v8 -
I don't see any negative reviews on pioneers 60 dollar subwoofer over at crutchfield. Besides what I was saying is companys capable of making top notch stuff across all lines.
Now Mac don't get me wrong polk subs sound good they have good sound quality at moderate levels but polk subs cannot stand to be pushed very hard. They work good for you because you are a heavy metal guy. -
Hey I am a heavy metal guy myself. Maybe I should be looking into Polk for my SQ subs as well?
Polk subs do well for what theyre designed to do. Theyre designed to provide good SQ, theyre not designed to get loud.
What youre saying is comparable to saying, a Honda Civic isnt great because they cant tow a trailer...well no ****, theyre not designed to...
Well I'm wanting a really great SQ sub but can also get very loud if it wants to.
