Hearing Voices
uncyogi
uncyogi Posts: 24
looking for a bit of help from some of you experts on a wierd situation. Not sure where to post this but it's a sub issue so I'll try here. I recently moved to an area where there is alot of commercial traffic close to the house and now my Polk sub has started acting like a tuner and picking up CB chatter which it brodcasts during playback of my discs adding snippets of conversations that weren't part of the scipt. Anyone heard of this happening before? Is this a normal occurance or is something wrong with my sub? Any suggestions to shield the sub or somehow stop this? Thanks guys.
Post edited by uncyogi on
  • jdhdiggs
    jdhdiggs Posts: 4,305
    edited January 2007
    That's odd. Try messing with the X-over on your sub. See if you can "tune" them out. If you can, your sub connections (whether from a speaker or sub input) are picking it up and you'll need better shielded cables. If you can't tune it out, it's likely something in the amp itself and you should contact polk support.
    There is no genuine justice in any scheme of feeding and coddling the loafer whose only ponderable energies are devoted wholly to reproduction. Nine-tenths of the rights he bellows for are really privileges and he does nothing to deserve them. We not only acquired a vast population of morons, we have inculcated all morons, old or young, with the doctrine that the decent and industrious people of the country are bound to support them for all time.-Menkin
  • BIZILL
    BIZILL Posts: 5,432
    edited January 2007
    it's most definatley 'white noise'!!!!! be afraid, be very afraid!:(
    actually, you're getting sounds from your sub? isn't your sub crossed over at the sub itself? if so, it is indeed spirits from 'the other side'. somehow you must be getting inteference somewhere up along the signal chain. your receiver most decidedly. imho.
    ONKYO TX-SR805
    CENTER: CSI5
    MAINS: RTI8'S
    SURROUNDS: RTI8'S
    7.1 SURROUNDS: RTI6'S
    XBOX 360
    WiiPS3/blu-rayTOSHIBA HD-A35 hd dvd
    http://polkarmy.com/forums/index.php
    bobman1235 wrote:
    I have no facts to back that up, but I never let facts get in the way of my arguments.
  • uncyogi
    uncyogi Posts: 24
    edited January 2007
    Thanks! I'll try the x-over adjustments first since that's free but I think your other suggestion makes more sense to me. I do have a pretty cheesy cable in use that may well be acting as an antenna. I knew when I used it that I would eventually have to replace it but it was the only one I had on hand that was long enough. Thanks again, I do believe you're on to something!
  • sucks2beme
    sucks2beme Posts: 5,689
    edited January 2007
    Are there any classic CB "white trash" hobbyists close by?
    Look for the BIG antennas. Just one of these guys with
    a hacked big power linear(very illegal) will bleed over into everything.
    Other than that, better cables, different positioning should help with the problem.
  • gregure
    gregure Posts: 871
    edited January 2007
    Besides better cables, I would suggest using a good line conditioner/power center for your system if you don't already. That will help clean up any ambient noise that may be coming through your line. I'm a big fan of Panamax, and after many side-by-side comparisons (I used to work in an electronics store), I have every confidence in saying that Panamax units are far better than Monster units. They clean the power more, yield better results from your equipment, and have better protection. Honestly, I wouldn't spend less that $500.00 on a line conditioner, but I've seen what a $1000 unit can do so I'm a little biased. They do make ones that are only $200 or so. Happy problem solving.
    Current System:
    CSi5-Center (for sale**)
    FXi3-surrounds (for sale**)
    Martin Logan Depth-Sub
    B&K AVR 507
    Pimare CD21-CD Player
    Denon 1815-DVD Player
    Panamax M5500-EX-Line Conditioner
  • pblanc
    pblanc Posts: 261
    edited January 2007
    I hear voices over my sub too. They tell me to go out and buy more audio gear. Maybe a marketing strategy on the part of speaker manufacturers? Or perhaps I just need to adjust my medication dosage.
  • ben62670
    ben62670 Posts: 15,969
    edited January 2007
    Yes Yes I hear those same voices too!
    Ben
  • wingnut4772
    wingnut4772 Posts: 7,519
    edited January 2007
    OMG! Me too!!!:D
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000 A
    Parasound HCA 1000
    Oppo BDP 95
    Von Schweikert LCR 4 Center
    Totem Mask Surrounds X4
    Sony PS3
    Squeezebox Touch
  • Ricardo
    Ricardo Posts: 10,634
    edited January 2007
    Voices? I hear voices, music, news.....in the telephone, in the computer. Luckily it does not affect my HT/2 Channel (Unless I put my finger one inch away from the pre tubes; if I do, I don't need a source. Music will come out of the speakers...). We fixed the phone issue with a filter in the line; only the extension in the basement has the issue now.
    HUGE antenna about 500 ft from the house.
    SOPA
  • beardog03
    beardog03 Posts: 5,550
    edited January 2007
    WOW !
    That`s a big antenna !
    I`m kinda supprised they gave him a permit for something so large in that type of area
    Parasound HCA-3500
    Cary Audio V12 amp (Jag Red)
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    MIT Shotgun S1 I/C`s
    AQ Black Thunder Sub Cables
    PS Audio Plus Power Cords
    :cool:
  • Ricardo
    edited January 2007
    beardog03 wrote:
    WOW !
    It was there many many years before anyone thought of building houses here....
    http://hawkins.pair.com/wlw.shtml
    "The single, omnidirectional, double diamond-shaped halfwave tower is now 747 feet high. It weighs 135 tons and was built by Blaw-Knox"
    SOPA
  • Ricardo
    edited January 2007
    Interesting read by the way; anyone needs 5 ft. tubes???
    SOPA
  • danger boy
    danger boy Posts: 15,722
    edited January 2007
    my older PSW 350 subwoofer on occasion would also pick up CB radio chatter sometimes. so i sold it. never had any other sub do that since.
    PolkFest 2012, who's going>?
  • mjhughes
    mjhughes Posts: 14
    edited January 2007
    You may have a faulty cable running to the sub. The shielding may be damaged or broken inside the cable. That can cause that problem.
  • bknauss
    bknauss Posts: 1,441
    edited January 2007
    Couple of things:
    1. Standards for passing EMI/EMC certification have changed over the years. If its an older sub, its more likely that it would be able to pick up stray interference and play it over the sub. Early versions of the RT3000 sub were able to pick up an AM station in Baltimore fairly well from what I've heard.
    2. The low pass filter might be too high. Knock it down to filter out that stuff.
    Brian Knauss
    ex-Electrical Engineer for Polk
  • Deadof_knight
    Deadof_knight Posts: 980
    edited February 2007
    Wonder what power rating those big tubes got. Take hell of a big box to cover them bad boys up might even have to make a bigger shelf for that amplifier.
    :cool: " He who dies with the most equipment wins Right ? "
    Denon 3300 Adcom 535 BBe w/sub out 1 pr 4.6s 2 pr of 4 jrs Recent additions Samsung Lns-4095D LCD, Samsung hd-960 DVD, Monster HT-5000 Power center
    ,HPSA-1000 18" sealed DiY home sub.:D
    Black Laquer 1.2tl's w/ upgraded x-overs and Tweets BI-Amped with 2 Carver tfm-35's Knukonceptz 10ga cables
