Need Amp Advice for DB6500's + MMC690's
MadCad
I'm a Nube in the car audio scene but just got a pair of db6500's and a pair of MMC690's.
Looking forward to install, but would like to power them.. minimum 100 W x 4 @ 4ohms.
Anyone got any advice about which Amp to go with? (preferrably inexpensive)
Post edited by MadCad on
Well, the polk 400.4 is not inexpensive, but it is a quality amp that will provide your 100 wats per channel.1970 Mach 1: ///ALPINE DVA 9860 H.U and H701 processor. Image Dynamics CSX 52 components, and IDQ D4 Sub. Polk/Momo 400.4 and 500.1 amps.
Go here and pick the best one you can afford.polkaudio sound quality competitor since 2005
I'll check out the Polk 400.4 for sure. Thanks
thanks for the link MacLeod. I'm sure there's something out there that will suit. -
The Polk 400.4 is not rated at 100 w rms @ 4 ohm, but at 2 ohm. (75w rms @ 4ohm) You are asking for something with more wattage. I have a hifonics Tx8805 which is supposed to be 110 w rms @ 4 ohm, but I wish I had the 400.4 as it seems much better quality.
If you insist on that power, another one is Infinity 7540a or 7541a.
I"d stay with the Polk though.
Demon -
You could check out the Alpine (V12) MRV-F545, rated at at least 125x4 @ 4 ohms- the tested performance on the birth sheet will probably exceed that. If you don't mind buying online (and forgoing Alpine warranty for one from the e-tailer) the price is pretty reasonable.
http://www.techronics.com/index.cfm?fuseaction=product.display&Product_ID=2143&gclid=CNj4g_e1_IkCFQ4iggodiWNwLg
Alpine MRV-F545 4-Channel Amplifier (though this retailer goofed on the specs)
http://www.polkaudio.com/forums/newreply.php?do=newreply&noquote=1&p=572899
Club Polk - Reply to Topic
I have been using the MRV-F345 and find it's been really clean and reliable so far. -
DemonAstroth wrote:The Polk 400.4 is not rated at 100 w rms @ 4 ohm, but at 2 ohm. (75w rms @ 4ohm)
Demon
I appreciate that, however my birth sheet shows that my 400.4 is pumping 93 watts per channel at 4 ohms. The Polk amps are underrated.1970 Mach 1: ///ALPINE DVA 9860 H.U and H701 processor. Image Dynamics CSX 52 components, and IDQ D4 Sub. Polk/Momo 400.4 and 500.1 amps.
