question on impedance
2000AccordSE
ok i noticed that if i buy 2 plain 12'' dbs the impedences on them is 4 ohms but if i get the box from polk its two, is it just a matter of wiring a certain way? cause im probally going to get 2 12'' momos or dbs with no box. originally i was gonna get the dbs in the polk box with a kicker 750.1
will 2 12'' momos and the 750.1 (2 ohms) work together?
Post edited by 2000AccordSE on
Very cool link Russ. That pretty much explains it.
You should read that Accord to get a good understanding of impedance but the short answer is yes. A pair of DB 12's each with a single voice coil will be a 2 ohm load if wired in parallel.polkaudio sound quality competitor since 2005
ok i get everything now except svc and dvc, whats the main difference and is one better sounding or what?
An SVC is short for single voice coil and DVC is short for dual voice coil.
For short if you buy an 4 ohm svc then it would take two of these to get a 2 ohm load to an amp.
If you get a 4ohm DVC then you can have your amp see a 4ohm load from this singel sub or wire the two 4 ohm Voice coils on this sub to show your amp a 2ohm load from this single sub.
As for SQ I do not think there is a difference just more flexabilty for your amp and install, making them great subs to change amps out or add subs being that you will have more options.
Hope this helps!!
DonnyNEWEST RIDE:
2006 Silver Jaguar XKR Coupe with factory BBS 20" and upgraded Brembo Brakes from factory....
Supercharger Pully Upgrade
Air Intake
Mina Exhaust System....
2007 Chevy Tahoe (Daily Driver):
Front Doors POLK sr6500
Amp front JL 450/4
Amp Sub JL 500/1
Sub JL 10w6
(Work Trucks)
2005 Mercury Mountaineer Premier 4.6L V-8
All Stock!!! In the process of changing this.
2002 Chevy Silverado 2500HD 4x4 Crew Cab 6.6L Diesel -
The enclosure actually changes the behavior of the driver(s) and alters their impedance.Lexicon Toshiba Crown EAW
