Hughesnet Satellite Internet Question.
cmy330go
cmy330go Posts: 2,341
edited January 2007 in The Clubhouse
Just curious if anyone here can tell me what kind of wiring is used between the satellite dish and the receiver/modem, and also how many runs are required.
My parents are building a new house in a rural area and would like to pre-install the wiring to avoid excess mess around the exterior of their new house.
Any help would be appreciated.
Dave
HT
Mits WD-65737, DirecTV, Oppo DV-970HD, XBOX ONE, Yamaha RX-A1030, Parasound Halo A23, Rotel RB-985, Music Hall MMF-7, Parasound PPH-100, LSi-15, LSi-C, LSi-FX, LSi-7, PSW-1000, Monster HTS2600
2 CH
Parasound Halo P3, Parasound Halo A21, Sutherland Ph.D, VPI Classic 3 w/ 3D arm & Soundsmith Aida Cartridge, Arcam CD72T, B&W 802 S3, Monster HTS2500,
Post edited by cmy330go on
  • jeremie
    jeremie Posts: 246
    edited January 2007
    i would look into Wild Blue. I have it and i am pretty happy with it. I believe that it rates better than Hughesnet. It takes two coax cables i believe 3ghz.
    Receiver Yamaha 3070 *Emotiva xpa5 * Behringer iNuke 6000dsp *Monster Cable HTS 3500 -- line conditioner * Panamax 5300 * Apple 4K * Panasonic UB820 * JVC NX5 * Silver Ticket thin bezel 120”
    LSIM - Fronts 707 * Center 706c * Sides 702 * Rear 703 *FP RC85i * RP RC65i * Sub (2) SI HT18
  • cmy330go
    edited January 2007
    So just two RG-6 lines. That's what I was guessing, but I couldn't seem to find any details about it elsewhere.
    Seems like wild blue is about $10/mo cheaper on the base package, but the same on their higher speed options.
    Also when you say they get higher ratings, what are you referring to? Customer service, connections speeds, etc...??????
    HT
    2 CH
  • jeremie
    jeremie Posts: 246
    edited January 2007
  • Systems
    Systems Posts: 14,872
    edited January 2007
    Hello
    I also had Wildblue for about a year, had very good luck with it although there wasn't as many people on my beam as there was over in the Eastern part of the US. They had some issues with overloading the beams. They also just launched a new satellite so I would think the overcrowding issues shouldn't be a problem now.
    Heres a forum that I frequented quite a bit when I had it:
    http://www.dslreports.com/forum/wildblue
    And this one:
    http://www.wildblue.cc/wbforums/index.php
    The only reason I quit it is because our local ISP rolled out their wireless dsl so I switched over to that.
    Testing
    Testing
    Testing
  • cmy330go
    edited January 2007
    Are either of you able to receive TV over the same dish? I had someone try to tell me that they had DirectTV and Internet over the same dish, but from what I have read you have to have two separate dishes. Is that not the case?
    BTW....What direction does your dish point??
    Later
    HT
    2 CH
  • jeremie
    jeremie Posts: 246
    edited January 2007
    i have two dishes and it points to the southern sky like satallite tv does.
