A little help on sub cables please.
Rivrrat
Rivrrat Posts: 2,101
I'm opening up my walls this week to run surround cables. I have 10b's in a 13x20 room, and I don't feel the need for a sub right now, BUT, just in case someday I want one, I want to place a sub cable while the walls are open.
Are powered sub cables just regular rca jack connecting cables, or are they coax with rca connectors? I understand they're passing a low frequency signal, but I want to use what's best.
I really don't want to have to open up these same holes for 3rd time, so I'd like to do it right.
Thanks in advance for answering a noob question.
My equipment sig felt inadequate and deleted itself.
Post edited by Rivrrat on
  • Willow
    Willow Posts: 11,227
    edited January 2007
    It's a regular coax cable with rca ends.
    For fun I've made my own with leftover coax cable and some screw-on RCA ends...
  • AndyGwis
    AndyGwis Posts: 3,655
    edited January 2007
    Wow, Willow, Canadians sure know how to have fun :)
    Purely kidding, love my neighbors to the north.
    Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
    Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850
  • Willow
    edited January 2007
    Well I do that in between feeding of the polar bear and repairs to the roof on my igloo ;)
  • IanD
    IanD Posts: 59
    edited January 2007
    You forgot about clipping the dog sled teams nails.:D
    Yamaha RX-V1500
    Pioneer Elite DV-46AV
    Scientific Atalana 8300 PVR-HD
    Panasonic TH-42PX60U
    Polk RTi10
    Polk CSi5
    Polk F/Xi3
    Polk PSW 350
    Mike's IC's
    DIY speaker cables (Kimber 4VS Shotgunned)
  • Rivrrat
    edited January 2007
    Thanks for the responses, and keeping a noob question light.
    Now to shop. I'm glad my wife indulges me on some issues. ;)
  • Sansui
    Sansui Posts: 372
    edited January 2007
    Screw-on as opposed to crimp-on? You didn't really use them did you? They're an accident waiting to happen. We use them for camera work and for emergencys only and then replace them with crimp-ons when we get them in stock .
    Be gentle, I'm new to all this...
    The mind blowing speed of the BRAIN TRAIN...
  • mKvDuBBy
    mKvDuBBy Posts: 34
    edited January 2007
    Can you use a regluar RCA cable and use that for a subwoofer cable. I just want to hear my sub today. And I ordered my cables from Signal but they are not to be here until next week. I was just wondering if you can just split the R and L rca cable and just use one of them? I cant wait thats why. Is it going to break anything?
  • WilliamM2
    WilliamM2 Posts: 4,806
    edited January 2007
    Yes, you can use a regular RCA interconnect. It won't hurt anything.
  • AndyGwis
    edited January 2007
    Willow, I'm in Dallas, TX. Nothing but Cowboy boots, hats, steer roaming the streets, etc. A day in my life is pretty much like watching Urban Cowboy.
    Actually, a couple of my consultants are from Canada and we were laughing about stereotypes over lunch today. That's why I chimed in with the wise-crack. . . fresh on my mind.
  • Willow
    edited January 2007
    Andrew, it's all good.....
    As for the cable I made..Yes screw on types to a left-over long piece of coax cable had lying around the house....As far as an accident...the only thing I could see happen is that I **** my finger on the coax or the sound cuts out...other than that....It was an experiment that lasted ohhhh about 3 days.
  • McLoki
    McLoki Posts: 5,231
    edited January 2007
    Since subs tend to pick up hum (and have a longer cable run) sub cables are often a little better sheilded than standard RCA cables. If I was going to run one in a wall, I would get an actual sub cable, but in a pinch - standard RCA interconnnect cables work just fine.
    Michael
  • Rivrrat
    edited January 2007
    The dreaded hum...Hmmmmm.
    Out of curiosuty and because of what I do at work, has anyone tried to run a ground wire off the ring of an rca connector to a ground point to try to eliminate hum? We use a lot of shielded cable at work, and I'm figuring it should work the same way, but being new and all..........
    In retrospect I'm thinking a standard interconnect wouldn't work (you'd probably just be grounding out the signal, if the ring is connnected to anything at all), but if you're using coax I think might.
    tonyb Posts: 33,069
    edited January 2007
    Actually,I've used a standard audio I/C ,well,not exactly standard,to get rid of hum from 2 SRT subs,and it not only worked,it tighten up the bass.But for inwall,a well shielded cable is needed.
