Should I Biwire my csi40 center channel
esoteric1222
I am wondering how much of a difference I will hear if I biwire my csi40 center channel speaker. I am running it off of a new Harman Kardon avr525. Any help would be great!!!!!
Post edited by esoteric1222 on
I can't tell you what you will hear, but why not?
Go for it. -
Can anyone explain why you should buy wire? Hey want more do you need if you have THX certified, high quality speaker wire?
Is this biwire thing overkill? -
Well I still have not gotten an answer. I am just wondering if it is worth it to biwire my center channel. Will it sound better? Any experiences? Thanks
Some will say, yes it makes a difference and others will say it makes no difference. I noticed a difference on my CS400i, but the only way to know for sure it to try it yourself. Good luck.
I would, at a minimum, try it. If you like it, fine, if you don't, well then you know.
Having said that, I don't feel that biwiring is a no-brainer gimmie in terms of improved sound quality.
Thanks guys!
