Should I Biwire my csi40 center channel
esoteric1222
I am wondering how much of a difference I will hear if I biwire my csi40 center channel speaker. I am running it off of a new Harman Kardon avr525. Any help would be great!!!!!
Post edited by esoteric1222 on
I can't tell you what you will hear, but why not? Go for it.
Can anyone explain why you should buy wire? Hey want more do you need if you have THX certified, high quality speaker wire?
Is this biwire thing overkill? -
Well I still have not gotten an answer. I am just wondering if it is worth it to biwire my center channel. Will it sound better? Any experiences? Thanks
Some will say, yes it makes a difference and others will say it makes no difference. I noticed a difference on my CS400i, but the only way to know for sure it to try it yourself. Good luck.
I would, at a minimum, try it. If you like it, fine, if you don't, well then you know.
Having said that, I don't feel that biwiring is a no-brainer gimmie in terms of improved sound quality.
Thanks guys!
