What kind of cables do you use?
esoteric1222
I am wondering what kind of cables you all use for your HT systems. I am in the market to get all new cables. Also if you guys could help me out with some online sites with great prices on great cables. Thanks!!!!
Post edited by esoteric1222 on
The classic, and famous! HD! SPEAKER WIRE! and GOOD OL RADIOSHACK AV CABLES!Damn you all, damn you all to hell.......
I promised myself
Damn you all! - ATC -
A mix of MIT, Signal Cable, Monster, Straight Wire, Rockford Fosgate, and Audioquest.
Check out Audioadvisor.com, and Signalcable.com to start(mention to Frank you are a Club Polk member for a discount @ Signal Cable).
Cheers,
RoosterCheck your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service. -
MIT, check them out at www.mitcables.com.Political Correctness'.........defined
President of Club Polk -
Audioquest Sidewinders and G-strings for interconnects and Type two speaker cable for the fronts and center. The rears and outdoor speakers had to be inwall speaker wire due to building codes. http://www.audioquest.com/ is the link"Just because youre offended doesnt mean youre right." - Ricky Gervais
"Consistency requires you to be as ignorant today as you were a year ago." - Bernard Berenson -
I'm using a mix of Monster and tributaries on my components right now, upgrading to Monster reference soon. Circuit City has monster reference interconnects (1m) for $69 (reg. 99).
Basic JPW bi-wire for my speakers.
Lots of good suggestions have already been made.
Audioquest Ruby Interconnects (great cables)
Monstercable front speakers
12 gauge for other speakers (Home Depot)
AR - S-video,component,sub
usedcables.com -
Monster cable from top to bottom.Pioneer Elite VSX-21TXH
Monolith 7x200 Amplifier
Harmony Hub
Sony VLP-HW40ES
Visualapex 106" Electric Screen
Oppo BDP-103
Music Hall MMF 2.1
Polk LSiM 705
Polk LSiM704c
Polk LSiM702F/X
SVS PB-2000 -
Mid grade Monster for A/V, and HD for speaker wire, with Monster QD banana plug terminations.
Doc"What we do in life echoes in eternity"
SVS -
speaker wire.. Liberty High Def. 14 guage same as monster but less $
IXOS sub cable 18ft
interconnects between pre outs and mono amps SilverCat cables
www.catcables.com $90 .5 meter pairPolkFest 2012, who's going>?
entry-level Monster, Audioquest Sidewinder, RShack gold, & from-the-box for analog & digital interconnects, & 16-G Acoustic Research for spkrs. Nothing fancy.Testing
Testing
Testing -
Speaker cables:
14 gage THX certified Monster Cable inwall speaker cable. (not in the wall) for the HT system
Powerline 2 from 1986 by Monster Cable for my SDA-SRS beauties
All my interconnects are various Monster Cable reference standard grades. I use component video for the DVD, and Toslink for the audio. I also have a monster power supply to filter the lines and provide clean power to the system.
There is better than monster out there but high end monster is good enough for me. -
I use Monster Cable and Transparent.
I have M2.2's for Left, Center, and Right. Monster 14 Gauge for the rears.
I also use Monster M1000CV for Component Video cables and I use Transparent Video for all S-Video sources.
Audio- I use Transparent Analog Interconnects for SACD and CD.
The rest of my sources have Monster M550I Analog interconnects and I also use the Monster HTS 5000 power conditioner.
Soon I will be upgrading to all Monster M1000I interconnects.
I think if you are looking for a great wire at a cost effective price I would definitely look into Monster as they can satisfy your needs at any level of audio or video.:p
