What kind of cables do you use?
esoteric1222
esoteric1222 Posts: 7
I am wondering what kind of cables you all use for your HT systems. I am in the market to get all new cables. Also if you guys could help me out with some online sites with great prices on great cables. Thanks!!!!
Please view my car audio page at
[http://members.sounddomain.com/esoteric1222]
Post edited by esoteric1222 on
  • MxStYlEpOlKmAn
    MxStYlEpOlKmAn Posts: 2,116
    edited December 2002
    The classic, and famous! HD! SPEAKER WIRE! and GOOD OL RADIOSHACK AV CABLES!
    Damn you all, damn you all to hell.......
    I promised myself
    Damn you all! - ATC
  • RuSsMaN
    RuSsMaN Posts: 17,985
    A mix of MIT, Signal Cable, Monster, Straight Wire, Rockford Fosgate, and Audioquest.
    Check out Audioadvisor.com, and Signalcable.com to start(mention to Frank you are a Club Polk member for a discount @ Signal Cable).
    Cheers,
    Rooster
    F1nut Posts: 52,243
    MIT, check them out at www.mitcables.com.
  • shack
    shack Posts: 11,154
    Audioquest Sidewinders and G-strings for interconnects and Type two speaker cable for the fronts and center. The rears and outdoor speakers had to be inwall speaker wire due to building codes. http://www.audioquest.com/ is the link
  • phuz
    phuz Posts: 2,372
    I'm using a mix of Monster and tributaries on my components right now, upgrading to Monster reference soon. Circuit City has monster reference interconnects (1m) for $69 (reg. 99).
    Basic JPW bi-wire for my speakers.
    Lots of good suggestions have already been made. :)
  • moorefield
    moorefield Posts: 23
    Audioquest Ruby Interconnects (great cables)
    Monstercable front speakers
    12 gauge for other speakers (Home Depot)
    AR - S-video,component,sub
    usedcables.com
  • Soccerplyr
    Soccerplyr Posts: 160
    Monster cable from top to bottom.
    Pioneer Elite VSX-21TXH
    Monolith 7x200 Amplifier
    Harmony Hub
    Sony VLP-HW40ES
    Visualapex 106" Electric Screen
    Oppo BDP-103
    Music Hall MMF 2.1
    Polk LSiM 705
    Polk LSiM704c
    Polk LSiM702F/X
    SVS PB-2000
  • Dr. Spec
    Dr. Spec Posts: 3,780
    Mid grade Monster for A/V, and HD for speaker wire, with Monster QD banana plug terminations.
    Doc
    SVS
  • danger boy
    danger boy Posts: 15,722
    speaker wire.. Liberty High Def. 14 guage same as monster but less $
    IXOS sub cable 18ft
    interconnects between pre outs and mono amps SilverCat cables
    www.catcables.com $90 .5 meter pair
    PolkFest 2012, who's going>?
  • Systems
    Systems Posts: 14,872
    entry-level Monster, Audioquest Sidewinder, RShack gold, & from-the-box for analog & digital interconnects, & 16-G Acoustic Research for spkrs. Nothing fancy.
    Testing
    Testing
    Testing
  • jdavy
    jdavy Posts: 380
    Speaker cables:
    14 gage THX certified Monster Cable inwall speaker cable. (not in the wall) for the HT system
    Powerline 2 from 1986 by Monster Cable for my SDA-SRS beauties
    All my interconnects are various Monster Cable reference standard grades. I use component video for the DVD, and Toslink for the audio. I also have a monster power supply to filter the lines and provide clean power to the system.
    There is better than monster out there but high end monster is good enough for me.
  • liv4fam
    liv4fam Posts: 311
    I use Monster Cable and Transparent.
    I have M2.2's for Left, Center, and Right. Monster 14 Gauge for the rears.
    I also use Monster M1000CV for Component Video cables and I use Transparent Video for all S-Video sources.
    Audio- I use Transparent Analog Interconnects for SACD and CD.
    The rest of my sources have Monster M550I Analog interconnects and I also use the Monster HTS 5000 power conditioner.
    Soon I will be upgrading to all Monster M1000I interconnects.
    I think if you are looking for a great wire at a cost effective price I would definitely look into Monster as they can satisfy your needs at any level of audio or video.:p
