Anyone heard of SpyderTV?
shawn474
I am looking to calibrate my display on my Panasonic Rear projection television. I have used the AVIA disk and something is still off in my opinion. I was researching and came across this:
http://www.costco.com/Browse/Product.aspx?Prodid=11183985&cm_mmc=BCEmail_187-_-Electronics-_-38-_-ColorVisionSpyderTV_BCEmail_187
Anybody have any experience with this or have any other suggestions to improve the picture?
Thanks,
Shawn
Thanks,
Shawn
Shawn
AVR: Marantz SR-5011
Center Channel: Polk LsiM706c
Front: Polk LsiM703
Rear: LSI fx
Subwoofer: SVS 20-39pci
DVD Player: Sony PS4
Front: Polk LsiM703
Rear: LSI fx
Post edited by shawn474 on
What do you think is off? Remember, even after calibrating you're going to want to do some fine tuning; especially with color.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
shawn474 wrote:I am looking to calibrate my display on my Panasonic Rear projection television. I have used the AVIA disk and something is still off in my opinion. I was researching and came across this:
Thanks,
Shawn
I've never tried it but I have read very good reviews on it's performance.
Here's one link, google for others.
http://www.audioholics.com/productreviews/avhardware/DatacolorSpyderTVreview.php -
I can't really pinpoint one thing that was off. After calibration with the AVIA disc, I found some scenes too red, others seemed washed out, and others seemed too dark. I amy just get a pro out here to calibrate, but thought I could do it by myself with the SpyderTV if anyone has heard of it or had good results with it.
ShawnShawn
Front: Polk LsiM703
Rear: LSI fx
DVD Player: Sony PS4 -
I'm probably going to get the SpyderTV pro within the next couple of months. After I get it, I'll do a short review of it. It was basically develped to do about 80-90% of what an actual ISF calibration would do, being basically designed by the people that do ISF's regularly.Tschüss
Zach -
I bought the Spyder TV a week after I purchased my plsama TV a few months ago and could not be happier about the outcome. The picture before calibration was nice but afterwards was unreal. The colors look perfect as well as the deep blacks. Probably one of the best investments I have ever made.58" Samsung Plasma (on wall)(calibrated)
LSi15's front (modded xo's)
LSic center
LSiFX's sides
LSi7's rears
Sunfire Sig. 600 amp for 15's
Sunfire Sig. Cinema for C,S&R
Sony ES 3000 pre/pro
SVS 2039 PC Plus sub 12.3 (16hz tune)
PS3
Wii
Signal and Audioquest ic's
12 awg monster speaker-cable (bi-wired)
Belkin PF60 power conditioner
Monster power conditioner for sub
