Amps - Class A-A/B reality
polkatese
polkatese Posts: 6,767
edited January 2007 in Electronics
For those amps which are rated to be Class A and A/B, is it fair to say that its presentation and slam while in the class A level is the reason why it is coveted? When I said slam, I meant also the micro-details.
From design perspective, is it considered to be in different class together, sort of the best of both worlds of pure Class A (too hot to handle) and Class A/B (lack of slam in lower volume)?
EE in the house, please educate me...
Thanks.
I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
Post edited by polkatese on
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited January 2007
    Part EE in the house here, why would an A/B amp have less slam at low volume over an A class amp in the first place? Do you have amp names / models that you're comparing?
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • McLoki
    McLoki Posts: 5,231
    edited January 2007
    Here is a pretty good (and technical) paper on class a amplifiers.
  • polkatese
    edited January 2007
    DJ7, not comparing any amps, but wondering about amps slam at lower volume, and its relation to the operating mode. Most of the amps in the 200+ watts are class A/AB (i.e. B&K Ref200.7, Gemstone, etc.)
    Michael, thanks for the linky. I am reading it right now.
  • disneyjoe7
    edited January 2007
    Ok so what am I missing here, I know for the most part class A amps can be cleaner sounding (less distortion) but what are you talking about less slam at low volume where did you hear that?
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • polkatese
    edited January 2007
    From what I read and experienced, class A has more slam at lower volume compared to class AB. But, I am not sure if it is absolute or really it's a function of amp design.
    F1nut Posts: 52,009
    edited January 2007
    Class A/B runs Class A at low wattage, some up to as much as 30wpc or so. If you run 90dB speakers, you're using 1 watt to achieve 90dB, so regardless of the amp being Class A or A/B, both are Class A at that point.....at least until you hit a big transient.
  • beardog03
    beardog03 Posts: 5,550
    edited January 2007
    I hit a transient once....but he had no class..!!
    sorry....carry on..!!
    I would actually like to learn what you are talking about...I`m just kinda tired
    Parasound HCA-3500
    Cary Audio V12 amp (Jag Red)
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    MIT Shotgun S1 I/C`s
    AQ Black Thunder Sub Cables
    PS Audio Plus Power Cords
    :cool:
    edited January 2007
    BINGO!!
  • zombie boy 2000
    zombie boy 2000 Posts: 6,641
    edited January 2007
    WAAAAAAAAAAAA!!!!
    :D Thanks Bear for the milk which speweth from mine nose onto our blessed computer screen fortwith says I verily. Amen.
    As for pure Class A, it's my understanding that the most notable perk is that of less distortion.
  • Deadof_knight
    Deadof_knight Posts: 980
    edited January 2007
    Oh man Class a , class a/b has to do with design. Class A is cleaner sounding and will typically handle transients better thus CLEANER. Class A runs hot as hell Class a/b is more efficient less heat with a lil sacrifice in the distortion percentage. But less slam at low volume , what amp are you speaking of or comparing?
    :cool: " He who dies with the most equipment wins Right ? "
    Denon 3300 Adcom 535 BBe w/sub out 1 pr 4.6s 2 pr of 4 jrs Recent additions Samsung Lns-4095D LCD, Samsung hd-960 DVD, Monster HT-5000 Power center
    ,HPSA-1000 18" sealed DiY home sub.:D
    Black Laquer 1.2tl's w/ upgraded x-overs and Tweets BI-Amped with 2 Carver tfm-35's Knukonceptz 10ga cables
  • Burnt
    Burnt Posts: 12
    edited January 2007
    Class A- A/B amps are a good combo of low level dynamics and loud and cooler when needed.
