Dressing Cables
hearingimpared
hearingimpared Posts: 21,136
I'm getting ready to dress the cables on my 2 ch rig. I was curious as to whether there was a new philosophy on doing so.
What I planned on doing was taking the power cords and in straight runs ty wrap them together straight down behind a piller. If there is any excess I was going to spread the excess out under the rack without coiling them up.
With the IC's I was planning on taking each pair and ty wrap them together and run them vertically down a rack piller on the opposite side of the power cord piller. If the ICs have to cross the power cords I am going to make them perpendicular i.e. 90 degrees to the power cords.
Any thoughts or feedback on this would be greatly appreiciated.
Post edited by hearingimpared on
  • steveinaz
    steveinaz Posts: 19,546
    edited January 2007
    Sounds good, just don't bundle them overly tight. Keep AC away from everything else. and keep digital isolated from IC's (unless it's fiber optic, of course).
    If the IC's/or speaker cables have to cross AC, place a piece of 2" thick styrofoam between the junction, or other material to maintain some airspace.
    Hit Rat Shack and buy a bag full of ty-wraps and some ty-wrap strap downs, they're great for hundreds of projects.
  • hearingimpared
    edited January 2007
    Thanks for the info Steve.
    Wow I didn't think digital signals could have any effect on analog IC's, what is the theory behind that?
    Also wouldn't placing styrofoam between the power cable/IC juction cause an inordinate amount of capacitance or stray capacitance?
    It used to be the theory that a 90 degree cross would have no effect whatever on the crossong analog wire . . . I guess more has been revealed over the years.
  • steveinaz
    edited January 2007
    I'm no techno-wizard, trust me, but I've read that it's a good idea to keep digital IC's away from analog IC's--so I always have.
  • TN_Polk_Lover
    TN_Polk_Lover Posts: 243
    edited January 2007
    Everything that I have read says that the "90 degree" rule is very valid and should be observed. However, even at 90 degrees, if the cables are very close, some AC hum can be introduced. I have read that it is a good idea to leave at least 1 inch between power cables and other signal level cables. I really couldn't speak to the capacitance issue, though.
    BTW, you can also get cable ties at Home Depot in a larger quantity bag than what is usually available at Radio Shack. The cost per tie is lower in the larger quantities if you don't mind keeping extra's around the house. But me, I use them all the time for all sorts of things, so I usually get a bunch of them at a time in different sizes.
    Your plan sounds good to me! I've followed a similar plan on my equipment. I wish that all manufacturers would all have the AC cord coming out from the same side on everything, but inevitably, there will always be some things where the AC cord is on the right, some on the left.
    Robert
    You are officially in the high-end of the deep-end of the top-end.
    Bonus Room Over Garage:
    Toshiba 27" CRT TV
    Digital Source: Sony DVP-NS3100ES
    DVR: Panasonic DMR-ES15
    Denon 3806 AV Receiver
    - L/R Preamp out to Parasound HCA-1200 Amp
    Polk RTi70's, CSi40 Center, RTi38 Side Surrounds, RTi38 Back Surrounds
    Living Room: (2ch only)
    TV: Sony KV20-FV12
    DVD Player: Sony DVP-NS715P
    Yamaha R9 Receiver Polk RTi38's
  • ben62670
    ben62670 Posts: 15,969
    edited January 2007
    Ditto
    Speakers are also AC so I would keep them seperate from the IC's too.
    Ben
  • Polkersince85
    Polkersince85 Posts: 2,883
    edited January 2007
    I like the tech-flex tubing myself from PE. Do a search for "flex" at their site to bring up all of them.
    http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=082-348
  • IanD
    IanD Posts: 59
    edited January 2007
    To keep cables off the carpet, I made up some small wood blocks to keep excess cable lengths off the floor. I concaved the end that the cables were resting on. Looks nice and tidy. They work great if the cables are stiff enough. I got the idea from a high end audio web site that was selling the same thing made from some exotic wood for 10 bucks each.
    I happened to have a piece of walnut hanging around the shop and made up a bunch of them in half an hour.
    I read somewhere that cables should never coil around themselves but lay in a zig zag or S shape.
    As well I found that the 3M brand of stick on hooks help in keeping cable against the wall behind the TV stand. They say a picture is wrth a thousand words. i'll take a couple of images and post them this weekend.
    Yamaha RX-V1500
    Pioneer Elite DV-46AV
    Scientific Atalana 8300 PVR-HD
    Panasonic TH-42PX60U
    Polk RTi10
    Polk CSi5
    Polk F/Xi3
    Polk PSW 350
    Mike's IC's
    DIY speaker cables (Kimber 4VS Shotgunned)
  • hearingimpared
    edited January 2007
    Well there goes another $50 out the door!
  • hearingimpared
    edited January 2007
    Please do, I've been checking out cable risers and the prices are a little rediculous. The only place I've found affordable risers was a site Antny turned me onto Signal Cable, they have risers 8 for 40 bucks. Still $5 apiece seems a little steep for up-side-down clear plastic cups with concave cutouts on the top.
  • IanD
    IanD Posts: 59
    edited January 2007
    My weekend project of re-routing the rats nest is going to have to wait another week. Since I have the good cable risers hidden behind all the equipment, here is a shot of the first cable risers I made.
    3" tall with a 2 1/4 x 2 1/4 base. A real fast and simple DIY.
    You will notice the circumference vibration inhibitor module. Critical to apply if you cannot drill a round hole.
    WARNING!
    Cats, dogs and rug rats seem to be drawn to these like flies to doo-doo.
    Make a lot of them cause they will disappear.
    These are made of birch. Any hard wood will do. Depends upon what you have hanging around.
    Yamaha RX-V1500
    Polk RTi10
    Polk CSi5
    Polk F/Xi3
    Polk PSW 350
    Mike's IC's
  • hearingimpared
    edited January 2007
    WARNING!
    Thanks for the info:)
  • steveinaz
    edited January 2007
    You know, I was dressing my cables this morning...and I forgot...are the socks suppose to match the shirt?
    LOL
  • IanD
    IanD Posts: 59
    edited January 2007
    LOL
    Only if you are dressing them in cable pants.
    Yamaha RX-V1500
    Polk RTi10
    Polk CSi5
    Polk F/Xi3
    Polk PSW 350
    Mike's IC's
  • hearingimpared
    edited January 2007
    I have lots of them.
  • IanD
    IanD Posts: 59
    edited January 2007
    and I'm looking for some.....:)
    Yamaha RX-V1500
    Polk RTi10
    Polk CSi5
    Polk F/Xi3
    Polk PSW 350
    Mike's IC's
  • dorokusai
    dorokusai Posts: 25,631
    edited January 2007
    I wind all my cables around an iron spool that is plugged into an 120v outlet.
  • hearingimpared
    edited January 2007
    How well does that electro magnet work?:p
