Comparing the LSI series with Rockets and Axioms
mwaarna
mwaarna Posts: 280
edited February 2007 in Speakers
I was intending to purchase Polk LSi 15's from http://acousticsounddesign.com/ but i called to place the order for them and the first availability is 3 weeks.
Now since i have some time, i am loking for opinions on other brands..
What do you guys think of the Rocket RS450 it also has a Vifa tweeter sells for 900, but no low-end.
http://www.av123.com/products_product.php?section=speakers&product=90.1
Also what are your opinions on Axiom Floor standers either M60 or M80.
http://www.axiomaudio.com/m80ti_main.html
Click here To see My system
Polk LSI15,LSiC, LsiFX, SVS PB-12 Plus/2, Blue Jean Cables,Onkyo Pro PR-SC885P, Earthquake Cin
Post edited by mwaarna on
    VR3 Posts: 29,427
    edited January 2007
    I wouldnt even consider the Axiom line up.
    They freaking build their stuff out of cardboard practically. Cheap materials, cheap finishes, cheap drivers. More so compared to the RT series than the LSi series.
    Sadly though, if I were to buy a pair of speakers right now between the LSi and Onix - It would most likely be Onix. Sorry Polk.
    PS: The LSi series is excellent - but I just like the way the Onix line up looks. Haha. *sigh*
  • Kelley_Moore
    Kelley_Moore Posts: 57
    edited January 2007
    I can't speak for the M60 or M80, but I happen to like the QS8's for my surrounds. Sound is great for me with decent power to them. Didn't notice the cardboard.
    Good luck in your search.
    F1nut Posts: 51,771
    edited January 2007
    John K. loves Axiom, that's all you need to know that they suck.
    3 weeks will pass quickly.
  • surfntomm
    surfntomm Posts: 185
    edited January 2007
    hey just a little tid bit with acoustic sound design, they have no serial numbers obviously on the back, i have purchased 2 sets of speakers from them and they are perfect minus the serial number. i believe if you make one order with them, you can receiver 20% off the next one. you should inquire about that. you could purchase a center and sell it back on ebay for a similar price and use the discount on your towers if you do end up going the lsi route.
  • surfntomm
    edited January 2007
    i think that deal is only on ebay i think so see what their price is on ebay, same products.
  • Early B.
    Early B. Posts: 7,900
    edited January 2007
    Yeah, hold out for three weeks and order the Polks.
    "God grooves with tubes."
  • ohskigod
    ohskigod Posts: 6,505
    edited January 2007
    3 weeks is worth the wait for the LSi's, trust me :)
    I dont even have the remote notion of upgrading the LSi's in my hteater, especially when I see how much I would have to spend for what some would call a significant improvement (Von Scheikert?....Martin Logan....eeeesh, I have a mortgage dude!!!) :D
    Living Room 2 Channel -
    Upstairs 2 Channel Rig -
    heiney9 Posts: 25,432
    edited January 2007
    3 weeks to wait is a no brainer for the Lsi's. There isn't a speaker out there that I can think of that is better than the Lsi's in its price range. You'd have to spend a lot more to surpass their ultimate performance and then you are just moving up the ladder incrementally.
    Patience Grasshopper.......patience
  • Shizelbs
    Shizelbs Posts: 7,433
    edited January 2007
    Three weeks is nothing. Just spend that time buying new CDs to listen to.
  • mwaarna
    mwaarna Posts: 280
    edited January 2007
    3 weeks is still a decent amount of time.
    No hurt in checking out other brands and listening and chilling...
    Buddy of mine at work, didnt realize they were into HT stuff as well.
    He has a full B&W 600 S3 set at his place.
    DM604 S3 2x Fronts retail for 1400 a pair
    LCR60
    DM602.5 2x Rears
    Going to listem to the 604's and try and compare them to the LSi's.
    What is the Polkie consensus on the B&W's?
    I also requested auditions to Axioms and the Rockets.
    Every where i have read, axioms are constructed inadequately...
  • george daniel
    george daniel Posts: 12,096
    edited January 2007
    Gawd,,I love this place :)
    edited January 2007
    No harm in looking around and comparing. Just a note of caution when comparing, make sure it's a fair comparison. Listening to other people's equipment in their environment and then listening to other equipment in another environment isn't a good way to do it. So many times LSi's are misrepresented in a dealer showroom or are run by inadequate electronics. This can happen with other brands as well.
    I've heard some rumblings from people I know who thought the LSi's were just ordinary until they heard mine properly set-up with proper electronics. I used to be in that camp especially after hearing anything in the dealer showroom.
    IMO, LSi's should not be in the same sentence as Rockets or Axiom, they are that much better. As far as B & W you either like 'em alot or hate 'em alot. The last pair I listened to just didn't do it for me. Very forward and had a sucked out midrange.(can't remember the model but it was awhile ago). Keep in mind this was in the showroom so not the best environment as noted above.
    Have fun
  • MrNightly
    MrNightly Posts: 3,370
    edited January 2007
    Completely off topic, but I got hung up on your screen name. Mary Jane lover? It really sounds that way... m wa ar na?!? Brilliant!
    But I digress.
    Now back to you're regular scheduled programming...
    Honoured to be, an original SOPA founding member
    Stuff...
    RTi12's - front
    CSi5 - center
    FXi3's - surrounds
    RTi4's - surrounds
    SVS PB12-NSD/2 - sub :D:D:D
    Denon 3805
    Rotel RB-985 5-Channel Amplifier
  • mwaarna
    mwaarna Posts: 280
    edited January 2007
    But I digress.
    Your about the 5th person in the last year to mention that.
    If you thought my screen name of mwaarna was hilariously close to MJ...
    My name is Matti Waarna, and people butcher it and it sounds like Mary Jane if you say it all bunched up and fast.
    Haha.. Its great in the professional world.
  • McLoki
    McLoki Posts: 5,231
    edited January 2007
    And I was going to go to my grave believing that only parents magazines used the phrase Mary Jane as a descriptor......
    Michael
  • Refefer
    Refefer Posts: 1,280
    edited January 2007
    Out of curiosity, why are you buying it from there? Why not grab a pair off of Crutchfield and have it shipped out today? I'd think that be the best bet IMO. No waiting around to contemplate how to purchase inferior speakers ;)
    Lovin that music year after year.
    Main 2 Channel System
    Polk SDA-1B,
    Promitheus Audio TVC SE,
    Rotel RB-980BX,
    OPPO DV-970HD,
    Lite Audio DAC AH,
    IXOS XHA305 Interconnects
    Computer Rig
    Polk SDA CRS+,
    Creek Audio 5350 SE,
    Morrow Audio MA1 Interconnect,
    HRT Music Streamer II
  • McLoki
    McLoki Posts: 5,231
    edited January 2007
    Acoustic Sound Design is not an authorized dealer, so they can sell below the Polk set price. Long story short - $450 more to purchase from crutchfield.
    Michael
  • mwaarna
    mwaarna Posts: 280
    edited January 2007
    Mainly Due to price. This is my Fist HT. Price from Acoustic was under 1200 shipped, where as Crutchfield is 1500....
    and yes 300 bucks gets me original Manf. warranty, but Acoustic offers their own warranty that matches Polks...
    F1nut Posts: 51,771
    edited January 2007
    If you believe that one, I've got a bridge to sell ya along with some B&W's.
  • schwarcw
    schwarcw Posts: 7,358
    edited January 2007
    Very cool!;)
    Carl
  • Holydoc
    Holydoc Posts: 1,048
    edited January 2007
    I was thinking the same thing.
    As far as my opinion between the LSi and the Rockets (no opinion of Axioms), I have heard that both have very pleasing sounds to their owners. I have also been very impressed with the Rocket forums and the developers participation in that same forum. Like Polk members here, the rocket owners get very excited about any new upgrades or announcements about their systems. That says alot about a speaker when you have that kind of loyalty, customer support, and excitement about the product.
    I think you will be happy with either.
    Holydoc (Home Theatre Lover)
    __________________________________________
    Panasonic -50PX600U 50" Plasma
    Onkyo -TX-NR901 Receiver
    Oppo -Oppo 980HD Universal DVD Player
    Outlaw -770 (7x200watt) Amplifier
    PolkAudio - RTi12 (Left and Right)
    PolkAudio - CSi5 (Center)
    PolkAudio - FXi3 (Back and Surround)
    SVS - PB-12/Plus (Subwoofer)
    Bluejean Cables - Interconnects
    Logitech Harmony 880 - Remote
  • mwaarna
    mwaarna Posts: 280
    edited January 2007
    So i've been thinking...
    This is my first Venture into HT, and i know that i will catch the upgrade bug eventually, why not just start off small...
    So i have been thinking of getting a used pair of LSi9's and some nice looking stands, and then i could get my Sub alot faster than i would have normally been able to get.
    I can most likely pick up a used set for LSi9's for 500ish and a decent stand for 150ish which would be about half price of the LSI15's.....
    Only thing is, if i get the 9's i would almost immediately after have to get a good Sub, but the money i would save over the 15's i dont see that being a problem.
  • Pepi28
    Pepi28 Posts: 248
    edited January 2007
    Looks like you got it figured out. On sub's, go for an SVS sub.
    58" Samsung Plasma (on wall)(calibrated)
    LSi15's front (modded xo's)
    LSic center
    LSiFX's sides
    LSi7's rears
    Sunfire Sig. 600 amp for 15's
    Sunfire Sig. Cinema for C,S&R
    Sony ES 3000 pre/pro
    SVS 2039 PC Plus sub 12.3 (16hz tune)
    PS3
    Wii
    Signal and Audioquest ic's
    12 awg monster speaker-cable (bi-wired)
    Belkin PF60 power conditioner
    Monster power conditioner for sub
  • mwaarna
    mwaarna Posts: 280
    edited January 2007
    Just before i make offers on Audiogon..
    How much do LSi9's typically go for used and shipped?
    Cause they are asking for about 500, what is an offer i could make them without having them totally ignore me.
    On the sub portion i've been doing research as well.
    The #1 contender currently is the HSU VTF-3 HO. Subs are alot easier to research and find out which ones are the best vs speakers..
    Depends on on how good the reviews for the new SVS Ultra and the price difference, but more than likely i will order the HSU
  • zombie boy 2000
    zombie boy 2000 Posts: 6,641
    edited January 2007
    You're not going to find much better than $500.
  • zombie boy 2000
    edited January 2007
    I take that back...
    http://cls.audiogon.com/cgi-bin/cls.pl?spkrmoni&1173826657
    Looks like there are three people selling 'em, so nows the time to jump. To be honest with you, all three prices are the lowest I've ever seen. Try to get one of them to throw in shipping and you've got a stellar deal.
  • mwaarna
    mwaarna Posts: 280
    edited January 2007
    I contacted both of the sellers of LSi9's on Audiogon to see if the are still available..
    Lets see what happens.
  • polkatese
    polkatese Posts: 6,767
    edited January 2007
    Check out this one:
    http://cls.audiogon.com/cgi-bin/cls.pl?spkrfull&1173834309
    great price, and upgraded caps. I would love to hear what it does to the sound.
    Just a FYI, no affil.
    I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
  • mwaarna
    mwaarna Posts: 280
    edited January 2007
    polkatese wrote:
    Check out this one:
    I looked at those...
    Zero reputation, plus he states no shipping... IDk, i would be very very weary about having those shipped with either UPS or Fedex.... If they were in florida i would totally consider it.
    Also now that i am looking at LSi9's....
    What do you guys recommend for stands, i would like them to be nice looking, which was one of the reasons i was leaning towards the LSi15s instead of the 9's.
  • polkatese
    edited January 2007
    I use Sanus Steel Foundation series. solid and looks good.
