3.1 tl repair
SLOCOOKN
SLOCOOKN Posts: 704
edited January 2007 in DIY, Mods & Tweaks
On the inside of right speaker the mdf is cracked in all 4 corners about 4 inches long. the top plate is off and 1 brace was knocked loose.
Would it be best to use 8 metal corner brackets. One above and one below the crack and fiberglass over the top or just fiberglass..?? how to affix the top plate?
Any Ideas?
Thanks,
Steve
:eek: From the bottom it looks like a steep incline, From the top another down hill slope of mine.:mad: But I know the equilibrium's there!:cool: .."Faith No More" :D
Sony cx985v (for now)
BBE 482i
B&K AVP 1030
Adcom GFA 555 mk 2
AudioQuest Crystal 2 spk wire
Nordost RCA
SDA 3.1 tl RD0 tweets
Belkin pf60
Carver TFM 55x
Signal Analog 2 RCA
AudioQuestType 4
VMPS Original Tall Boy (Mega Woofers soon)
Post edited by SLOCOOKN on
  • SLOCOOKN
    SLOCOOKN Posts: 704
    edited January 2007
    I went ahead and used 8 corner braces to secure the corners. I then applied an epoxy in the corners and over the corner braces. It turned out very solid. Perhaps not the best approach? That said, I am sure it is very secure now.
    Still not sure what is best for top plate...any ideas?
    BBE 482i
    B&K AVP 1030
    Adcom GFA 555 mk 2
    Nordost RCA
    Belkin pf60
    Carver TFM 55x
    Signal Analog 2 RCA
    AudioQuestType 4
    F1nut Posts: 51,729
    edited January 2007
    By top plate I'm quessing you mean the wood end cap, right?
  • SLOCOOKN
    SLOCOOKN Posts: 704
    edited January 2007
    Correct the lid or top of the speaker.
    BBE 482i
    B&K AVP 1030
    Adcom GFA 555 mk 2
    Nordost RCA
    Belkin pf60
    Carver TFM 55x
    Signal Analog 2 RCA
    AudioQuestType 4
    F1nut Posts: 51,729
    edited January 2007
    I'm not sure about the 3.1TL's, but with the other TL models the end caps are bolted on. Since it sounds like that is not the case with yours, I'd have to say glue it on. Liquid Nails works well.
  • SLOCOOKN
    SLOCOOKN Posts: 704
    edited January 2007
    I was hoping you would reply.. the top was formerly glued on with 90 degree wooden pieces. no bolts...Oddly though one end cap is solid wood and the other is mdf...kinda strange i thought.
    It is to late for this pair...If I should ever have a similar problem what would be the best solution for repair..The crack ran parallel to the corner about 1 inch to two inches from inside corner.
    BBE 482i
    B&K AVP 1030
    Adcom GFA 555 mk 2
    Nordost RCA
    Belkin pf60
    Carver TFM 55x
    Signal Analog 2 RCA
    AudioQuestType 4
    F1nut Posts: 51,729
    edited January 2007
    That is strange. I wonder if the solid wood cap is a replacement someone put on?
    I assume the crack was in the MDF, so I'd probably use West System marine epoxy and clamp the hell out of it.
  • Polk65
    Polk65 Posts: 1,405
    edited January 2007
    Solid wood end caps here and they are glued (pic1).
    Check beneath your speakers. Are there four little adjustable feet or screw holes where they might go?
    While your are poking around inside have a look at the sides of your speakers. They might be lacking some glue (pic2).
    pic1: top
    pic2: side
    F1nut Posts: 51,729
    edited January 2007
    Steve, I'm 99% positive that Polk gave up on solid wood caps after the SDA SRS's. Can you see end grain on the edges of the caps?
  • Polk65
    Polk65 Posts: 1,405
    edited January 2007
    Jesse, You caught me assuming. :rolleyes: The outside edges have banding. These SRS 3.1TL's are the first vintage Polk Audio speakers that I have seen where the inside end caps look like unstained wood. All of the other's I have seen use raw MDF inside. If you look carefully, there are wood shavings in the left corner that I chose to keep.
    (photo1) Raife posted an inside photo of SRS 1.2TL end caps with a visible stain. http://www.polkaudio.com/forums/showthread.php?t=26036
    (photo2) SRS 3.1TL inside bottom end cap
    (photo3) SRS 3.1TL inside bottom end cap close-up
    Jim's SRS 3.1TL's are similar.
    post #6 http://www.polkaudio.com/forums/showthread.php?t=26506
    If it's only wood veneer, these were attached after the sides.
    Steve
    F1nut Posts: 51,729
    edited January 2007
    Looks like veneer to me.
  • SLOCOOKN
    SLOCOOKN Posts: 704
    edited January 2007
    Sorry for all the controversy. The end cap is mdf. It has a real wood looking veneer. It looks like real wood...nice and solid. On further inspection it is mdf. These are sda's. My end caps look different than polk65's. If you were to cut a felled tree on a horizontal plane the veneer looks like the same grain pattern...very real looking! Thanks for all the advise..
    Steve
    BBE 482i
    B&K AVP 1030
    Adcom GFA 555 mk 2
    Nordost RCA
    Belkin pf60
    Carver TFM 55x
    Signal Analog 2 RCA
    AudioQuestType 4
  • DarqueKnight
    DarqueKnight Posts: 6,765
    edited January 2007
    The end caps of my 1.2TL's are MDF with oak veneer on both sides and edge banding. After removing one of the end caps, I unscrewed one of the retaining bolts to see how thick the veneer was. It appeared to be about 1/8", which is fairly thick for speaker veneer.
  • Ricardo
    Ricardo Posts: 10,636
    edited January 2007
    Mine are also veneer....but you only get it if you look very closely. Good stuff.
    SOPA
  • Polk65
    Polk65 Posts: 1,405
    edited January 2007
    Ricardo, did you notice if your end caps are unstained wood veneer inside?
  • Ricardo
    edited January 2007
    I honestly don't remember.......
    SOPA
  • SLOCOOKN
    SLOCOOKN Posts: 704
    edited January 2007
    Mine are unstained...That's why I thought they were real wood at first.
    BBE 482i
    B&K AVP 1030
    Adcom GFA 555 mk 2
    Nordost RCA
    Belkin pf60
    Carver TFM 55x
    Signal Analog 2 RCA
    AudioQuestType 4
  • Ricardo
    edited January 2007
    Unstained veneer. Had to get in there to remove the by-pass caps.
    SOPA
