bi amp or single amp
goingganzo
would it be better to bi amp at 100 wpc or get a amp that has 200 wpc?
Post edited by goingganzo on
I've been checking out bi-amping at some other sites. From what I gather if done correctly with the correct amps, speakers, & wire it can be really sweet and be quite an improvement. If not done correctly you can damage your speakers and/or amps.
I'd go with a 200wpc and bi-wire. Or if the 100wpc amps in question are bridgable, go with a bi-wired dual mono configuration.Make it Funky!
your going to need 2 amps. run your highs on the 100wpc L/R and your subs on the 200wpc L/Ra true audiophile is never satisfiyed
Actually i have read to use equal size amps and pref. the same brand. I have done this with my rti70's, I have a 2 channel amp with 4 outputs(speakers A&B) and at 165 wpc i put each output on each the tweeter and woofers, seemed to work good, can't say i noticed a difference when i switched back to regular bi-wireing them on 1 output each speaker. The highs actually are not so bright as it doesnt have 165 going straight to each one.MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
LSIfx surround backs
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Rotel 1080 stereo amp
Polk sda 2B
kenwood grunt Tuner
realistic lab 450 TT
Signal cable IC
