Am I crazy to think about placing an LCD on top of my Center Ch. Spkr?
brentski
I've been looking everywhere for a stand that will accomodate my CS400i center channel speaker (as it's 8 5/8" high) on the middle shelf of a TV System (and I'm not having any luck)
Is it nuts to think about placing the center channel speaker on the top shelf of a stand and in turn,place a 40" LCD TV w/ base on top of the speaker,and leaving me with the center shelf to place my components which is what it's made for?
Would the vibrations from the speaker. screw up the TV? OR....Is this just a crazy idea I'm thinking of at 3 in the AM?
Am I nuts or..............
Any help or suggestions would be greatly appreciated.
Thanks,
brentski
Thanks,
brentski
Center; CS-400i
Main's; RT-55's
Side Surround's-RT-35's
Rear center;CS-300
Sub; SVS PB12-NSD
Main's; RT-55's
Rear center;CS-300
Sub; SVS PB12-NSD
Post edited by brentski on
I'm thinking your tv only weighs 55/65 lbs. As long as it's stable enough and you're not sliding it around (scratch the veneer) you're probably fine. Vibrations from a center that size aren't really going to affect anything. Just make sure your tv won't tip over if you bump it. Not sure what tv you have but some tv stands are sketchy as is. Samsung pedestals are notoriously wobbly.
I wouldnt put my speakers through that...
Big vote of no.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
The placement should not be an issue, but I would not use the pedestal base for your tv. Is there any way to adapt a wall mount to acutally suspend the TV in the air above the center channel?
Personally I would not place it on the center channel (to much to lose if it tips over) but putting the TV above the center should not be a problem.Mains.............Polk LSi15 (Cherry)
Go ahead and place the TV on your center channel. As long as it's stable, there shouldn't be a problem.
Add a barrier between the TV and center channel to prevent scratches. Maybe some felt fabric or some of that rubber stuff used to line cabinets.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
Yeah, i think the biggest issue would be stability.Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
Backburner:Krell KAV-300i -
I wouldn't do it.. the speaker may rumble is off the center channel and onto the floor.. and TV go bye bye,PolkFest 2012, who's going>?
My guess is that the continue vibrations from the speaker would eventually cause out of focus or convergence problems. Or maybe other issues with internal components. No speaker is vibration proof.Monitor 7b's front
Monitor 4's surround
M10's back surround
Harman/Kardon AVR-635
Oppo 981hd
Denon upconvert DVD player
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
Dont BAN me Bro!!!!:eek: -
I would not put it on my center speaker. There is definitely vibrations with mine. Why can't it be mounted to the wall?Oppo bdp 93 Blue Ray
Integra DTR-80-2
Polk LSi9s (mains)
Polk LSiC (center)
Polk LSiFXs (surrounds)
Sub SVS 20-39+
Samsung 60" Led 3-d
Blue Jean Cables -
jakelm wrote:My guess is that the continue vibrations from the speaker would eventually cause out of focus or convergence problems. Or maybe other issues with internal components. No speaker is vibration proof.
Focus and convergence? On an LCD?
Oh an LCD... Whoops!!
But still it could rattle something loose.Monitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
I need to read sloooooowwwweeeerrrr.....Monitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
It's a veneered cs400i... as long as he has something in between the two he won't do any damage to either componnent. If it were say an lsiC I'd say no because the finish is too easy to mess up. Obviously it's not a great idea but if he's very very careful placing the tv onto it I think it'll be fine. My sub shakes my tv more from 5 feet away than my center would if I placed it on top...
Or if you have minimal woodworking skills, build an "A" frame. |^^^^|Monitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
