Am I crazy to think about placing an LCD on top of my Center Ch. Spkr?
brentski
brentski Posts: 96
edited January 2007 in Electronics
I've been looking everywhere for a stand that will accomodate my CS400i center channel speaker (as it's 8 5/8" high) on the middle shelf of a TV System (and I'm not having any luck)
Is it nuts to think about placing the center channel speaker on the top shelf of a stand and in turn,place a 40" LCD TV w/ base on top of the speaker,and leaving me with the center shelf to place my components which is what it's made for?
Would the vibrations from the speaker. screw up the TV? OR....Is this just a crazy idea I'm thinking of at 3 in the AM?
Am I nuts or..............
Any help or suggestions would be greatly appreciated.
Thanks,
brentski
Center; CS-400i
Main's; RT-55's
Side Surround's-RT-35's
Rear center;CS-300
Sub; SVS PB12-NSD
Post edited by brentski on
  • michael_w
    michael_w Posts: 2,813
    edited January 2007
    I'm thinking your tv only weighs 55/65 lbs. As long as it's stable enough and you're not sliding it around (scratch the veneer) you're probably fine. Vibrations from a center that size aren't really going to affect anything. Just make sure your tv won't tip over if you bump it. Not sure what tv you have but some tv stands are sketchy as is. Samsung pedestals are notoriously wobbly.
    VR3 Posts: 29,445
    edited January 2007
    I wouldnt put my speakers through that...
    Big vote of no.
  • McLoki
    McLoki Posts: 5,231
    edited January 2007
    The placement should not be an issue, but I would not use the pedestal base for your tv. Is there any way to adapt a wall mount to acutally suspend the TV in the air above the center channel?
    Personally I would not place it on the center channel (to much to lose if it tips over) but putting the TV above the center should not be a problem.
  • Early B.
    Early B. Posts: 7,900
    edited January 2007
    Go ahead and place the TV on your center channel. As long as it's stable, there shouldn't be a problem.
    Add a barrier between the TV and center channel to prevent scratches. Maybe some felt fabric or some of that rubber stuff used to line cabinets.
    "God grooves with tubes."
  • unc2701
    unc2701 Posts: 3,587
    edited January 2007
    Yeah, i think the biggest issue would be stability.
    Backburner:Krell KAV-300i
  • danger boy
    danger boy Posts: 15,722
    edited January 2007
    I wouldn't do it.. the speaker may rumble is off the center channel and onto the floor.. and TV go bye bye,
    PolkFest 2012, who's going>?
  • jakelm
    jakelm Posts: 4,081
    edited January 2007
    My guess is that the continue vibrations from the speaker would eventually cause out of focus or convergence problems. Or maybe other issues with internal components. No speaker is vibration proof.
    Monitor 7b's front
    Monitor 4's surround
    M10's back surround
    Harman/Kardon AVR-635
    Oppo 981hd
    Denon upconvert DVD player
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
    Dont BAN me Bro!!!!:eek:
  • doug lang
    doug lang Posts: 261
    edited January 2007
    I would not put it on my center speaker. There is definitely vibrations with mine. Why can't it be mounted to the wall?
    Oppo bdp 93 Blue Ray
    Integra DTR-80-2
    Polk LSi9s (mains)
    Polk LSiC (center)
    Polk LSiFXs (surrounds)
    Sub SVS 20-39+
    Samsung 60" Led 3-d
    Blue Jean Cables
  • unc2701
    edited January 2007
    Focus and convergence? On an LCD? :confused:
  • jakelm
    jakelm Posts: 4,081
    edited January 2007
    Oh an LCD... Whoops!!
    But still it could rattle something loose.
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • jakelm
    jakelm Posts: 4,081
    edited January 2007
    I need to read sloooooowwwweeeerrrr.....
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • michael_w
    edited January 2007
    It's a veneered cs400i... as long as he has something in between the two he won't do any damage to either componnent. If it were say an lsiC I'd say no because the finish is too easy to mess up. Obviously it's not a great idea but if he's very very careful placing the tv onto it I think it'll be fine. My sub shakes my tv more from 5 feet away than my center would if I placed it on top...
  • jakelm
    jakelm Posts: 4,081
    edited January 2007
    Or if you have minimal woodworking skills, build an "A" frame. |^^^^|
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
