Can I put my home sub in my car?
neokeelo
ok, so I just installed some Infinity reference speakers in my car.
(2) 4 inch and (2) 6.5 inch. I am not satisfied with the bass output of this setup.
I have 2 home theater subs.
One is a 10" 100 watt passive Kenwood The other is a Jensen 12" 100watt powered sub.
Instead of buying a car subwoofer and an amp. Can I just buy a DC to AC converter and use the powered sub?
Here is what the powered sub looks like except it is front firing.
http://cgi.ebay.com/JENSEN-JS-1000A-12-100-WATT-DOWN-FIRING-SUB-LIKE-NEW_W0QQitemZ250068709896QQihZ015QQcategoryZ3275QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
what should I do?
what should I do?
My System
Pre/Pro - Integra DTR 40.2
Amplifier -Parasound 2205a
Paradigm Studio 60s V5 Mains
Paradigm Studio 590 V5 Center
Paradigm 20s - rear ( Wanted)
SUB - SVS PB12-NSD
LG PK250 60inch Plasma
SUB - SVS PB12-NSD
Post edited by neokeelo on
I hate the hijack the thread but is there any way to hook a car sub up in my room?Dodge Dakota
HU: Pioneer
Amp: Profile AP600 & Phoenix gold r2.5:2
Speakers: Boston SX 6.5 components
Subwoofer: polk mm2104 -
Person A - neokeelo
Person B - vawakmonster
Person A. Send your home sub to Person B
Person B. Send your car sub to Person A.
Problem Solved. That was easy.
I suppose you could do that, although it would be a lot easier and less time consuming to just buy a sub and amp for your car.
As for the car sub in the home, sure. Just make sure the amp youre using to power it can handle a 4 ohm mono load. Most home audio gear is 8 ohm.polkaudio sound quality competitor since 2005
at one point in my life i found myself with a ton of car audio gear and no car.
i built some tower enclosures for my speakers and purchased a nice 120 to 12v convertor and had one hell of a 2 channel car audio system in my house(wish i had pics)
and at one point before i had nice car audio gear i ran some home speakers cabinets and all in my truck off an alphasonic 50 watt amp
as far as using a dc convertor to run the home amp you might run into some problems with the convertor shutting off with the demand for power. but hey give it a try you never know it might just get you by and create conversation (maybe a headache or 2
i'm with Macleod it might be easier to just get a sub and amp designed for carSpeakers:
Definitive BP7001sc mains
Definitive C/L/R 3000 center
Polk RT800i's rears
Definitive supercube I Sub
Audio:
Onkyo TX-NR3010
Emotiva XPA five Gen 3
OPPO BDP-103 CD, SACD, DVD-A
Video:
Panasonic TC-P65ZT60
OPPO BDP-103 Bluray
Directv x's 2 -
No one likes my solution
very clevr BL, very clevr..!!
and quick response too...gotta get points for that !
I thought it made sense.....the `ol switcherooCary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Cary Audio V12 amp (Jag Red)
Jolida JD-100 CDP
SVS PC-Ultra Sub
MIT Shotgun S1 I/C`s
AQ Black Thunder Sub Cables
PS Audio Plus Power Cords
:cool: -
BL has the easy method.
On the power converter (as previously mentioned), unless you get a big one, you will exceed whats its capable of providing. You are talking at least $200-400 for a decent one. Would be cheaper to get an amp and sub for a car.Panasonic CQ-TX5500 Japanese Tube
PrecisionPower DCX-730 Processor
McIntosh MMC446
polkaudio SR6500 x2
polkaudio SR104DVC x 2 -
beardog03 wrote:very clevr BL, very clevr..!!
i thought it was pretty clever myself
Now if they did that it would be amazing lol:D -
lpreston wrote:BL has the easy method.
Honestly, to run most car audio gear, you will need a power supply that is capable of handling at least a 30 amp constant draw with double the peak amperage. Yes, you can get bench power supplies that will do that kind of power but you are talking about...literally, a small welding power supply.
Also, it is insanely inefficient. Speakers are speakers fundametally and if you want to put car speakers in enclosures and use them in your home, it can be a successful venture. However, it is best to get an amp wired to run off of the 120v outlet in your house. A simple 100 watt per channel stereo amp for your home will use less than 1/4 of the power the DC power supply and car amp would use.Expert Moron Extraordinaire
Jstas wrote:Also, it is insanely inefficient. Speakers are speakers fundametally and if you want to put car speakers in enclosures and use them in your home, it can be a successful venture.
The only thing you need to look at is your ohm load. Most home drivers will be 8 ohm and car normally is 4...but some car subs will vary anywhere from 2 ohm up depending on how you will wire with (series or parallel) and with how many will be used. A car amp will vary tremendiously in its output based on the ohm load of the sub array.Panasonic CQ-TX5500 Japanese Tube
McIntosh MMC446
polkaudio SR6500 x2
You could always follow this guy's lead.
If you have extra home audio subs and not enough car audio subs.... why not sell the one you have extra of for money to buy the one you want more of..?If you will it, dude, it is no dream. -
lpreston wrote:The only thing you need to look at is your ohm load. Most home drivers will be 8 ohm and car normally is 4...but some car subs will vary anywhere from 2 ohm up depending on how you will wire with (series or parallel) and with how many will be used. A car amp will vary tremendiously in its output based on the ohm load of the sub array.
Amplification is amplification, fundamentally. If you see a home amp that is 8-4 ohm capable but it has the same power output at any impedance, it has a regulated power supply. Any non-regulated power supply should almost double in power output if you cut the impedance in half.
There are also quite a few stereo amplifiers for your home that will handle 4 ohm speakers without a problem. Most car speakers are marked with thier ratings and only the drivers designed for extreme SPL will have 2 ohm examples. Those are not recommended for any system that would be used for critical listening. They make noise and alot of it. That's it. However, if you had two 2 ohm load subs, they can be wired to present a 4 ohm load. You can wire two 8 ohm subs to present a 4 ohm load also. When speaking of circuits, speakers are resistors and all the rules of circuits apply.
Officially, I am going to go on the record as saying this is not such a great idea. I am using a car sub at home but it's powered with a home based amp running off of standard 120V out of the wall. The DC power supply idea is not exactly the safest, generates a good deal of heat and in a few cases, has exposed power leads which can be shorted and start fires. For teh car, a home sub would not be ideal by far. The enclosures are not built sturdy enough to handle the abuse a car can dish out and thier amps will draw a good deal of current on a power inverter. That creates alot of heat and can starve teh amplifier of power which would then make it clip and start destroying stuff.
I'd just get a sub and amp for the car and call it a day.Expert Moron Extraordinaire
Success!
I did not spend one penny and I got exactly what I wanted.
I used the powered Jensen sub and my inverter to rig this up. The Inverter is running off the cigarette adaptor. The back of the inverter says to connect directly to the battery when using over 150 watts, but since this is only a 100 watt sub I think it will be ok. After letting it play for maybe 15 mins, I touched it and it was not even warm. I wired the sub into the front pre outs using 2 RCA cables. These pics are from tonight. I will eventually get these wires hidden and out of sight. Now I just need to get something to hold the sub in place. It sounds totally different now. The sub does not blow you away by any means but it does complete the sound stage nicely. Thanks for your help everyone.
My System
SUB - SVS PB12-NSD
LG PK250 60inch Plasma -
The wattage of the amp's output has nothing to do with the wattage it uses for input. Just because the sub's amp is rated at putting out 100 watts doesn't mean it's draw is 100 watts. The speaker uses DC power, the amp uses AC power as input and outputs DC power. There are transformers that step up voltage and step down voltage inside that amplifier plus it's own inverter circuit to convert the 120V AC house current to DC current.Expert Moron Extraordinaire
Is that a 90's Camry?
In UseGeorge Grand wrote: »
Epson 8700UB
In Storage
[Home Audio]
Klipsch RF-35, RB-51ii
[Car Audio]
Pioneer Premier DEH-P860MP, Memphis 16-MCA3004, Boston Acoustic RC520 -
Yea it is a 93My System
SUB - SVS PB12-NSD
LMAO!!!
Dude, that is the most ghetto thing Ive ever seen.polkaudio sound quality competitor since 2005
haha that looks hilarious, hide the wires and your good to go.
I think im gonna try and put some velodynes in my g35
Turn the sub around so the driver faces the rear, that way the wires are hidden and if anyone asks why you have a home theater sub in your car you can say "I'm on my way home from Best buy"
BaggedLancer wrote:Person A - neokeelo
Love IT Funny You got 100% on this reply.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
neokeelo wrote:Success!
The inverter on the cigarette adapter is ok if it is working ok right now. The 150 watts over will draw more then 15amps, the cigarette fuse would blow if it drawn over 150 watts.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Now that I can see the pictures, I agree with MacLeod. Ghetto. With a capital hetto.Expert Moron Extraordinaire
If you try hard enough you could have this setup....Alpine: CDA-7949
Alpine: PXA-H600
JL Audio: 10W6v2 (x2)
KnuKonceptz
Second Skin -
wow are all those wires actually going some where? it looks like a wire spewed in the trunk
Speakers:
Polk RT800i's rears
Audio:
Onkyo TX-NR3010
Video:
OPPO BDP-103 Bluray
Directv x's 2 -
haha blackmax i hope that isn't your car
That looks rediculous and is COMPLETELY unsafe. Look at all the exposed wires
I am afraid that it is................
j/k
... While that car is a Maxima, it is not one of the Maximas I own. This was the gear I had in my 4th Gen Maxima
Not as nice as the install with all those wires showing though.....
Alpine: CDA-7949
Alpine: PXA-H600
KnuKonceptz
Second Skin -
I'm not that big into car audio. I'm a home theater guy myself. :cool:
This setup works and sounds great for a poor college student like me.
My System
SUB - SVS PB12-NSD
You may want to give the advice that was given about turning the sub around a shot. Many times in a car's trunk you get better bass response with the subwoofer pointed towards the back of the car.Alpine: CDA-7949
Alpine: PXA-H600
KnuKonceptz
Second Skin -
niiiice, blackmax. What is your opinion on those amps?
Very nice amplifiers, I highly recommend them.Alpine: CDA-7949
Alpine: PXA-H600
KnuKonceptz
Second Skin
