Dissolve blue loctite
apc
Anyone know how to remove blue loctite from screw threads?
Husband, Father, Son, Brother, Friend.
Post edited by apc on
a vise and a makita wire brush.
Dremel has an attachment that looks kind of like a scotch pad. That should do it. be careful using anything metal as it could disrupt the threads on the screw.
ShawnShawn
AVR: Marantz SR-5011
Center Channel: Polk LsiM706c
Front: Polk LsiM703
Rear: LSI fx
Subwoofer: SVS 20-39pci
DVD Player: Sony PS4 -
shawn474 wrote:Dremel has an attachment that looks kind of like a scotch pad. That should do it. be careful using anything metal as it could disrupt the threads on the screw.
Shawn
Well, sure....I guess this would also work if you wanted the screw to have some threads left.:D -
Edit
Boil the screws in water. The locktite will soften enough to simply wipe off. Don't burn your fingers.
For bolts, use a Die. For nuts, use a tap.
Heat will soften and release blue Loctite. If it was the red stuff then you have to get physical with it.DKG999
Music System: Magnepan 1.6QR, SVS SB12+, ARC pre, Parasound HCA1500 vertically bi-amped, Jolida CDP, Pro-Ject RM5.1SE TT, Pro-Ject TubeBox SE phono pre, SBT, PS Audio DLIII DAC -
One of the red Loctites has to be heated to 450 or 500 degrees to get it to release.Sal Palooza
If the blue Loctite is what I think it is--2-ethylhexylmethacrylate polymer, aka crazy glue--then it will dissolve in acetone, and probably in most types of nail polish remover.
Cheers, JimA day without music is like a day without food. -
just get a big screw driver and break it lose or the right tool. i use it all the time on my rc car. sence all the set screws will fall off if i dont.
Turbousa65's saliva ought to eat right through that stuff.
I have always used gasoline
...or shell out $.10 and buy a new one...
