HK 7300 quit on me
PSOVLSK
PSOVLSK Posts: 5,400
edited January 2007 in Electronics
Watching the national championship game Monday night and my receiver all of a sudden turns off. I tried turning it back on, but each time it would turn back off. I unhooked everything, but still got the same results. Anyway, it's in for service and hopefully I won't be without it for too long. I'm mainly just sharing my bad fortune, but if anyone has any ideas on what happened, I'd be interested to hear them. The good news is that this all happened with only 3:00 left in the game.
Post edited by PSOVLSK on
  • BIZILL
    BIZILL Posts: 5,432
    edited January 2007
    i feel for ya. hopefully mine lasts quite awhile...
    ONKYO TX-SR805
    CENTER: CSI5
    MAINS: RTI8'S
    SURROUNDS: RTI8'S
    7.1 SURROUNDS: RTI6'S
    XBOX 360
    WiiPS3/blu-rayTOSHIBA HD-A35 hd dvd
    http://polkarmy.com/forums/index.php
    bobman1235 wrote:
    I have no facts to back that up, but I never let facts get in the way of my arguments.
  • danger boy
    danger boy Posts: 15,722
    edited January 2007
    how loud where you listening to it.. and what type of speakers do you have connected to it? it sounds like it was a power issue.. whereby the speakers were demanding to much from the receiver. causing it to go into what's called protect mode. usually though.. once you turn the receiver off and wait a couple minutes.. it's ok till it happens again. or it may not happen again.l
    PolkFest 2012, who's going>?
  • bobman1235
    bobman1235 Posts: 10,822
    edited January 2007
    Tough to find a power issue with a 7300, those things are BEASTS.
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited January 2007
    I think a output transistor and or driver bias transistor has "**** the Bed" If going on then off the receiver see's a power issue and is turning itself off.
    Maybe a BEAST but everything can DIE. ;)
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • PSOVLSK
    edited January 2007
    I have LSi7's, LSiC, Bose 301 for surrounds (my next upgrade), SVS Plus 12/2.I was listening at a low volume because everyone else was in bed...maybe -35 from reference. I usually watch movies at -20, but very seldom ever turn it up any more than that. Not sure if I stated the values correctly, but hopefully you know what I mean. I'm guessing this is something that should be repairable??
    Thanks.
  • zombie boy 2000
    zombie boy 2000 Posts: 6,641
    edited January 2007
    With Harman Kardon, it may very well be a heating issue. Those puppies run hot all the way down the line. I can only imagine how hot the 7300 gets....
    Is there enough clearance on all sides?
    edit: does this model have a built-in cooling fan?
  • PSOVLSK
    edited January 2007
    I should have plenty of clearance. About 20" above, 6" on one side, basically open on the other, and 4" in back. It's in an open audio rack. It does have a built in cooling fan.
    Make no mistake though, it does run very warm even with what I consider proper ventilation.
