Center Speaker Wiring Question
mark090852
mark090852 Posts: 998
I was wondering...
I have a set of the small Polk RM6005 home theater speakers that I'm not using the front right and left speakers at the present time. I was thinking of wiring the center channel speaker and the right and left front speakers together to use as a combined center chanel speaker. I know if I wire them in parallel I would be lowering the impedance and if I wired them in series I would be raising the impedance. What if I wired one in parallel and the other two in series. Would that keep the impedance at 8 ohms? I know this isn't the proper way to do it but I was hoping I might get a fuller sound from the three speakers together compared to just the small center speaker alone. This is just a temporary fix until I can get a better quality center speaker to replace these three.
McIntosh MA252 Integrated Amp, LUMIN D2 Network Music Player, Yamaha Aventage RX-A840 receiver, Emotiva XPA Gen3 2 channel amp, Polk LSiM 703 speakers. Oppo UDP-203 Blu-Ray player, Polk LSiM 705 speakers. Polk Signature S20 speakers.
Post edited by mark090852 on
    tonyb Posts: 33,072
    edited January 2007
    Ain't worth the risk involved bro.Leave it,save your dough and get what you really want.Depending on the other gear you have,you could do some damage.
  • mark090852
    edited January 2007
    Thanks guys, for the info. I'll follow your advice and just get a better center speaker. My theater setup is in a small room. Right now I have Monitor 50s in front and will go ahead and get a CS1 center to match....was just trying to find a way to use those smaller ones so they wouldn't be wasted.
    Thanks again for responding...I appreciate it.
    Mark
