Center Speaker Wiring Question
mark090852
I was wondering...
I have a set of the small Polk RM6005 home theater speakers that I'm not using the front right and left speakers at the present time. I was thinking of wiring the center channel speaker and the right and left front speakers together to use as a combined center chanel speaker. I know if I wire them in parallel I would be lowering the impedance and if I wired them in series I would be raising the impedance. What if I wired one in parallel and the other two in series. Would that keep the impedance at 8 ohms? I know this isn't the proper way to do it but I was hoping I might get a fuller sound from the three speakers together compared to just the small center speaker alone. This is just a temporary fix until I can get a better quality center speaker to replace these three.
McIntosh MA352 Integrated Amp, Bluesound Node Icon Reference Network Music Streamer, SVS Ultra Evolution Pinnacle Speakers
Post edited by mark090852 on
Ain't worth the risk involved bro.Leave it,save your dough and get what you really want.Depending on the other gear you have,you could do some damage.HT SYSTEM-
lsi 9's -
Thanks guys, for the info. I'll follow your advice and just get a better center speaker. My theater setup is in a small room. Right now I have Monitor 50s in front and will go ahead and get a CS1 center to match....was just trying to find a way to use those smaller ones so they wouldn't be wasted.
Thanks again for responding...I appreciate it.
MarkMcIntosh MA352 Integrated Amp, Bluesound Node Icon Reference Network Music Streamer, SVS Ultra Evolution Pinnacle Speakers
