What is the difference...
between the
PB12 Plus SVS
and the
PB12-NSD/2 SVS?
Both cost $899 in the black, but which is actually the better woofer? Anybody know off hand? Would be used mostly for HT, with probably 20% music.
Thanks.
PB12 Plus SVS
and the
PB12-NSD/2 SVS?
Thanks.
Honoured to be, an original SOPA founding member
Stuff...
RTi12's - front
CSi5 - center
FXi3's - surrounds
RTi4's - surrounds
SVS PB12-NSD/2 - sub
Denon 3805
Rotel RB-985 5-Channel Amplifier
Stuff...
RTi12's - front
CSi5 - center
FXi3's - surrounds
RTi4's - surrounds
Denon 3805
Post edited by MrNightly on
The Plus is the "better" woofer, while /2 is dual woofers.
Mike -
Well wouldn't 2 12 inchers, be better than 1?!Honoured to be, an original SOPA founding member
Stuff...
RTi12's - front
CSi5 - center
FXi3's - surrounds
RTi4's - surrounds
Denon 3805
Rotel RB-985 5-Channel Amplifier -
Some V6's out run and out pull some V8's. Its the quality, not the quantity.
JakeMonitor 7b's front
Monitor 4's surround
M10's back surround
Harman/Kardon AVR-635
Oppo 981hd
Denon upconvert DVD player
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
Dont BAN me Bro!!!!:eek: -
Not in this case ...MrNightly wrote:Well wouldn't 2 12 inchers, be better than 1?! -
You will get more output from the NSD/2's than you would the single plus. If you would email SVS, they will more than likely give you the best answer in under an hour.
Mike -
Look at the Fr graph on each page. The plus has approx 18hz @ approx 92.5dbs while the dual sub has the same teasting with only approx 18hz @ approx 85 dbs. So the one sub (PB12 Plus) being better quality, has a higher db at a lower Fr than the dual subs.Monitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
So better Fr extention @ lower Fr @ higher dbs w/ lower distortion = better sub. IMO
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
This is an interesting question as I have a PB12 Plus and am wondering why SVS would offer the two at the same price.Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000 A
Parasound HCA 1000
Oppo BDP 95
Von Schweikert LCR 4 Center
Totem Mask Surrounds X4
Sony PS3
Squeezebox Touch
wingnut4772 wrote:This is an interesting question as I have a PB12 Plus and am wondering why SVS would offer the two at the same price.
Wing-
The Plus is an upgraded model from the NSD series. Kinda like how the single Ultra is about as much as the dual Plus series subs.
Mike -
I guess that makes sense except the same price part. I actually have the PB12/Plus 2 and an Ultra/2.Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000
Oppo BDP 95
Sony PS3
Squeezebox Touch
I sent SVS an email. I'll see what they say, and report here with the findings!Honoured to be, an original SOPA founding member
Stuff...
RTi12's - front
CSi5 - center
FXi3's - surrounds
RTi4's - surrounds
Denon 3805
MrNightly
I'm definitely interested in what you find out, because I'm looking at the same subs right now.ncmarine
60" Sony SXRD
Denon AVR-2807
Adcom GFA 555Mk-II
Outlaw M2200 x 3
Fronts - RTi8s
Center - CSi5
Sides - Rti8s
Rears - RTi6s
Sub - PSW505
DVD - Samsung HD860
Playstation 3
XBox 360
Monster HTS2600 -
Gee, if a had a 12 incher, I think I could be satisfied with just one.
pblanc wrote:Gee, if a had a 12 incher, I think I could be satisfied with just one.
You wish....peewee!!:D
Couldn't resist......just bustin balls bro!HT SYSTEM-
lsi 9's -
Ok, here was Ed's response.
Hi David:
See more below at the *******.
We appreciate your interest in SV Sound and if you have any questions, just holler.
Ed
SVS
________________________________
Sent: Wednesday, January 03, 2007 12:59 AM
To: SVS - Tech Support
Subject: Question regarding two subs...
Hello there!
I had a quick question for you guys… ...and wanted to know what is the difference between the
PB12 Plus <http://www.svsound.com/products-sub-box-plus1.cfm> SVS and the PB12-NSD/2 <http://www.svsound.com/products-sub-box-isd2.cfm> SVS?
Both cost $899 in the black, but which is actually the better woofer? My sub will be used mostly for HT, with probably 20% music. I currently have my HT in a room about 15 X 26 with half the room with cathedral ceilings. There are also two open doorways in this room on the 8 foot ceiling part. Next year, I will be remodeling my basement, and plan to have a dedicated HT room set up down there. It will probably be about 15 x 25 feet, with just average ceiling height.
Between the two subs mentioned above, is there a better choice? Obviously, one has a superior driver I assume, but wouldn’t two woofers put out more umph than just the single driver?
*******Your are mostly correct here, David.
The native extension of the PB12-Plus is 20 Hz with all three 3" ports open. In order to obtain 20 Hz extension from the NSD/2, you need to plug a port, leaving you with dual 3" ports open.
At 18-23 Hz (very deep), the PB12-Plus and the PB12-NSD/2 will actually have similar output capabilities. Above 23 Hz, the NSD/2 will start to assert a progressively larger output advantage, worth about 50% more than the PB12-Plus over the more common bass regions.
The PB12-Plus also opens up the possibility of nicer finish options (for more $$), along with a PEQ control. The PEQ is a single-band parametric equalizer with three controls (frequency, cut, bandwidth) that allows the user to reduce the severity of a room-induced peak in the frequency response.
The PB12-NSD/2 is larger and heavier than the PB12-Plus, and only comes in textured black, and there is no PEQ option. While more utilitarian in nature, it's the performance enthusiast's subwoofer of choice in the $1,000 price bracket.********
Thank you for your time and help! You have quite the following on Polk Audio’s forum sight!
********Great bunch of guys over there - I've got over 3000 posts myself put don't visit there too often anymore (just not enough time in the day). **********
Regards,
David K.Honoured to be, an original SOPA founding member
Stuff...
RTi12's - front
CSi5 - center
FXi3's - surrounds
RTi4's - surrounds
Denon 3805
Does this really matter if one of the three ports is plugged? I wouldn't think so.Ed wrote:At 18-23 Hz (very deep), the PB12-Plus and the PB12-NSD/2 will actually have similar output capabilities. Above 23 Hz, the NSD/2 will start to assert a progressively larger output advantage, worth about 50% more than the PB12-Plus over the more common bass regions.
Sounds to me like the NSD/2 is actually the better woofer here. Might not hit just quite as low as the Plus but above 23 Hz, 50% more output?!? That's quite a bit to me!!!Ed wrote:The PB12-Plus also opens up the possibility of nicer finish options (for more $$), along with a PEQ control. The PEQ is a single-band parametric equalizer with three controls (frequency, cut, bandwidth) that allows the user to reduce the severity of a room-induced peak in the frequency response.
Does anybody have experience with this PEQ control? Is it a MUST have on a sub? Interesting.
I'm leaning toward the NSD/2 now. Seems it would be an all around better sub for me!Ed wrote:********Great bunch of guys over there - I've got over 3000 posts myself put don't visit there too often anymore (just not enough time in the day). **********
He obviously doesn't know jack about this site
Stuff...
RTi12's - front
CSi5 - center
FXi3's - surrounds
RTi4's - surrounds
Denon 3805
What Ed and other SVS staffers seldom address is the SQ difference mainly because it's subjective. The Plus delivers a more defined sound and in room extention in 16hz tune is around 13-14hz. However, the Plus just can't fill a larger room and will go into distress if pushed too hard. The /2 subs can handle the 4000^3 + rooms with plenty of headroom. In smaller rooms they produce gut busting pressurization. If you really want to feel the bass and have the room, the /2 subs are the way to go. If you're in a moderate room, you'll get plenty of bass from a single Plus with, IMO, better sound quality(than the NSD) and a tad more extention. If you opt for the PEQ (premium finish only) you can smooth out a peak for flatter FR. This works very well for alot of folks, however, it's not designed to dig out a null which can only be corrected through placement and room treatment.
Combo rig:
SDA 1C, CS400i, SDA 2B
PB13Ultra RO
BW Silvers
Oppo BDP-83SE
