What is the difference...
MrNightly
MrNightly Posts: 3,370
edited January 2007 in Speakers
between the
PB12 Plus SVS
and the
PB12-NSD/2 SVS?
Both cost $899 in the black, but which is actually the better woofer? Anybody know off hand? Would be used mostly for HT, with probably 20% music.
Thanks.
Honoured to be, an original SOPA founding member
Stuff...
RTi12's - front
CSi5 - center
FXi3's - surrounds
RTi4's - surrounds
SVS PB12-NSD/2 - sub :D:D:D
Denon 3805
Rotel RB-985 5-Channel Amplifier
Post edited by MrNightly on
  • MikeC78
    MikeC78 Posts: 2,315
    edited January 2007
    The Plus is the "better" woofer, while /2 is dual woofers.
    Mike
  • MrNightly
    edited January 2007
    Well wouldn't 2 12 inchers, be better than 1?!
    Stuff...
    RTi12's - front
    CSi5 - center
    FXi3's - surrounds
    RTi4's - surrounds
    Denon 3805
  • jakelm
    jakelm Posts: 4,081
    edited January 2007
    Some V6's out run and out pull some V8's. Its the quality, not the quantity.
    Jake
    Monitor 7b's front
    Monitor 4's surround
    M10's back surround
    Harman/Kardon AVR-635
    Oppo 981hd
    Denon upconvert DVD player
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
    Dont BAN me Bro!!!!:eek:
  • PolkWannabie
    PolkWannabie Posts: 2,763
    edited January 2007
    Not in this case ...
  • MikeC78
    edited January 2007
    You will get more output from the NSD/2's than you would the single plus. If you would email SVS, they will more than likely give you the best answer in under an hour.
    Mike
  • jakelm
    jakelm Posts: 4,081
    edited January 2007
    Look at the Fr graph on each page. The plus has approx 18hz @ approx 92.5dbs while the dual sub has the same teasting with only approx 18hz @ approx 85 dbs. So the one sub (PB12 Plus) being better quality, has a higher db at a lower Fr than the dual subs.
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • jakelm
    jakelm Posts: 4,081
    edited January 2007
    So better Fr extention @ lower Fr @ higher dbs w/ lower distortion = better sub. IMO
    Jake
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • wingnut4772
    wingnut4772 Posts: 7,519
    edited January 2007
    This is an interesting question as I have a PB12 Plus and am wondering why SVS would offer the two at the same price.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000 A
    Parasound HCA 1000
    Oppo BDP 95
    Von Schweikert LCR 4 Center
    Totem Mask Surrounds X4
    Sony PS3
    Squeezebox Touch
  • MikeC78
    edited January 2007
    Wing-
    The Plus is an upgraded model from the NSD series. Kinda like how the single Ultra is about as much as the dual Plus series subs.
    Mike
  • wingnut4772
    edited January 2007
    I guess that makes sense except the same price part. I actually have the PB12/Plus 2 and an Ultra/2.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000
    Oppo BDP 95
    Sony PS3
    Squeezebox Touch
  • MrNightly
    edited January 2007
    I sent SVS an email. I'll see what they say, and report here with the findings!
    Stuff...
    RTi12's - front
    CSi5 - center
    FXi3's - surrounds
    RTi4's - surrounds
    Denon 3805
  • ncmarine
    ncmarine Posts: 31
    edited January 2007
    MrNightly
    I'm definitely interested in what you find out, because I'm looking at the same subs right now.
    ncmarine
    60" Sony SXRD
    Denon AVR-2807
    Adcom GFA 555Mk-II
    Outlaw M2200 x 3
    Fronts - RTi8s
    Center - CSi5
    Sides - Rti8s
    Rears - RTi6s
    Sub - PSW505
    DVD - Samsung HD860
    Playstation 3
    XBox 360
    Monster HTS2600
  • pblanc
    pblanc Posts: 261
    edited January 2007
    Gee, if a had a 12 incher, I think I could be satisfied with just one.
    tonyb Posts: 33,068
    edited January 2007
    You wish....peewee!!:D
    Couldn't resist......just bustin balls bro!
  • MrNightly
    edited January 2007
    Ok, here was Ed's response.
    Hi David:
    See more below at the *******.
    We appreciate your interest in SV Sound and if you have any questions, just holler.
    Ed
    SVS
    ________________________________
    Sent: Wednesday, January 03, 2007 12:59 AM
    To: SVS - Tech Support
    Subject: Question regarding two subs...
    Hello there!
    I had a quick question for you guys… ...and wanted to know what is the difference between the
    PB12 Plus <http://www.svsound.com/products-sub-box-plus1.cfm&gt; SVS and the PB12-NSD/2 <http://www.svsound.com/products-sub-box-isd2.cfm&gt; SVS?
    Both cost $899 in the black, but which is actually the better woofer? My sub will be used mostly for HT, with probably 20% music. I currently have my HT in a room about 15 X 26 with half the room with cathedral ceilings. There are also two open doorways in this room on the 8 foot ceiling part. Next year, I will be remodeling my basement, and plan to have a dedicated HT room set up down there. It will probably be about 15 x 25 feet, with just average ceiling height.
    Between the two subs mentioned above, is there a better choice? Obviously, one has a superior driver I assume, but wouldn’t two woofers put out more umph than just the single driver?
    *******Your are mostly correct here, David.
    The native extension of the PB12-Plus is 20 Hz with all three 3" ports open. In order to obtain 20 Hz extension from the NSD/2, you need to plug a port, leaving you with dual 3" ports open.
    At 18-23 Hz (very deep), the PB12-Plus and the PB12-NSD/2 will actually have similar output capabilities. Above 23 Hz, the NSD/2 will start to assert a progressively larger output advantage, worth about 50% more than the PB12-Plus over the more common bass regions.
    The PB12-Plus also opens up the possibility of nicer finish options (for more $$), along with a PEQ control. The PEQ is a single-band parametric equalizer with three controls (frequency, cut, bandwidth) that allows the user to reduce the severity of a room-induced peak in the frequency response.
    The PB12-NSD/2 is larger and heavier than the PB12-Plus, and only comes in textured black, and there is no PEQ option. While more utilitarian in nature, it's the performance enthusiast's subwoofer of choice in the $1,000 price bracket.********
    Thank you for your time and help! You have quite the following on Polk Audio’s forum sight!
    ********Great bunch of guys over there - I've got over 3000 posts myself put don't visit there too often anymore (just not enough time in the day). **********
    Regards,
    David K.
    Stuff...
    RTi12's - front
    CSi5 - center
    FXi3's - surrounds
    RTi4's - surrounds
    Denon 3805
  • MrNightly
    edited January 2007
    Does this really matter if one of the three ports is plugged? I wouldn't think so.
    Sounds to me like the NSD/2 is actually the better woofer here. Might not hit just quite as low as the Plus but above 23 Hz, 50% more output?!? That's quite a bit to me!!!
    Does anybody have experience with this PEQ control? Is it a MUST have on a sub? Interesting.
    I'm leaning toward the NSD/2 now. Seems it would be an all around better sub for me!
    He obviously doesn't know jack about this site ;)
    Stuff...
    RTi12's - front
    CSi5 - center
    FXi3's - surrounds
    RTi4's - surrounds
    Denon 3805
  • Ron Temple
    Ron Temple Posts: 3,212
    edited January 2007
    What Ed and other SVS staffers seldom address is the SQ difference mainly because it's subjective. The Plus delivers a more defined sound and in room extention in 16hz tune is around 13-14hz. However, the Plus just can't fill a larger room and will go into distress if pushed too hard. The /2 subs can handle the 4000^3 + rooms with plenty of headroom. In smaller rooms they produce gut busting pressurization. If you really want to feel the bass and have the room, the /2 subs are the way to go. If you're in a moderate room, you'll get plenty of bass from a single Plus with, IMO, better sound quality(than the NSD) and a tad more extention. If you opt for the PEQ (premium finish only) you can smooth out a peak for flatter FR. This works very well for alot of folks, however, it's not designed to dig out a null which can only be corrected through placement and room treatment.
    Combo rig:
    SDA 1C, CS400i, SDA 2B
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
