What is the difference...
edited January 2007 in Speakers
between the
PB12 Plus SVS
and the
PB12-NSD/2 SVS?
Both cost $899 in the black, but which is actually the better woofer? Anybody know off hand? Would be used mostly for HT, with probably 20% music.
Thanks.
Honoured to be, an original SOPA founding member
Stuff...
RTi12's - front
CSi5 - center
FXi3's - surrounds
RTi4's - surrounds
SVS PB12-NSD/2 - sub :D:D:D
Denon 3805
Rotel RB-985 5-Channel Amplifier
Post edited by MrNightly on
Welcome!
    edited January 2007
    The Plus is the "better" woofer, while /2 is dual woofers.
    Mike
    edited January 2007
    Well wouldn't 2 12 inchers, be better than 1?!
    Stuff...
    RTi12's - front
    CSi5 - center
    FXi3's - surrounds
    RTi4's - surrounds
    Denon 3805
    edited January 2007
    Some V6's out run and out pull some V8's. Its the quality, not the quantity.
    Jake
    Monitor 7b's front
    Monitor 4's surround
    M10's back surround
    Harman/Kardon AVR-635
    Oppo 981hd
    Denon upconvert DVD player
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
    Dont BAN me Bro!!!!:eek:
    edited January 2007
    Not in this case ...
    edited January 2007
    You will get more output from the NSD/2's than you would the single plus. If you would email SVS, they will more than likely give you the best answer in under an hour.
    Mike
    edited January 2007
    Look at the Fr graph on each page. The plus has approx 18hz @ approx 92.5dbs while the dual sub has the same teasting with only approx 18hz @ approx 85 dbs. So the one sub (PB12 Plus) being better quality, has a higher db at a lower Fr than the dual subs.
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
    edited January 2007
    So better Fr extention @ lower Fr @ higher dbs w/ lower distortion = better sub. IMO
    Jake
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
    edited January 2007
    This is an interesting question as I have a PB12 Plus and am wondering why SVS would offer the two at the same price.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000 A
    Parasound HCA 1000
    Oppo BDP 95
    Von Schweikert LCR 4 Center
    Totem Mask Surrounds X4
    Sony PS3
    Squeezebox Touch
    edited January 2007
    Wing-
    The Plus is an upgraded model from the NSD series. Kinda like how the single Ultra is about as much as the dual Plus series subs.
    Mike
    edited January 2007
    I guess that makes sense except the same price part. I actually have the PB12/Plus 2 and an Ultra/2.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000
    Oppo BDP 95
    Sony PS3
    Squeezebox Touch
    edited January 2007
    I sent SVS an email. I'll see what they say, and report here with the findings!
    Stuff...
    RTi12's - front
    CSi5 - center
    FXi3's - surrounds
    RTi4's - surrounds
    Denon 3805
    edited January 2007
    MrNightly
    I'm definitely interested in what you find out, because I'm looking at the same subs right now.
    ncmarine
    60" Sony SXRD
    Denon AVR-2807
    Adcom GFA 555Mk-II
    Outlaw M2200 x 3
    Fronts - RTi8s
    Center - CSi5
    Sides - Rti8s
    Rears - RTi6s
    Sub - PSW505
    DVD - Samsung HD860
    Playstation 3
    XBox 360
    Monster HTS2600
    edited January 2007
    Gee, if a had a 12 incher, I think I could be satisfied with just one.
    edited January 2007
    You wish....peewee!!:D
    Couldn't resist......just bustin balls bro!
    edited January 2007
    Ok, here was Ed's response.
    Hi David:
    See more below at the *******.
    We appreciate your interest in SV Sound and if you have any questions, just holler.
    Ed
    SVS
    ________________________________
    Sent: Wednesday, January 03, 2007 12:59 AM
    To: SVS - Tech Support
    Subject: Question regarding two subs...
    Hello there!
    I had a quick question for you guys… ...and wanted to know what is the difference between the
    PB12 Plus <http://www.svsound.com/products-sub-box-plus1.cfm&gt; SVS and the PB12-NSD/2 <http://www.svsound.com/products-sub-box-isd2.cfm&gt; SVS?
    Both cost $899 in the black, but which is actually the better woofer? My sub will be used mostly for HT, with probably 20% music. I currently have my HT in a room about 15 X 26 with half the room with cathedral ceilings. There are also two open doorways in this room on the 8 foot ceiling part. Next year, I will be remodeling my basement, and plan to have a dedicated HT room set up down there. It will probably be about 15 x 25 feet, with just average ceiling height.
    Between the two subs mentioned above, is there a better choice? Obviously, one has a superior driver I assume, but wouldn’t two woofers put out more umph than just the single driver?
    *******Your are mostly correct here, David.
    The native extension of the PB12-Plus is 20 Hz with all three 3" ports open. In order to obtain 20 Hz extension from the NSD/2, you need to plug a port, leaving you with dual 3" ports open.
    At 18-23 Hz (very deep), the PB12-Plus and the PB12-NSD/2 will actually have similar output capabilities. Above 23 Hz, the NSD/2 will start to assert a progressively larger output advantage, worth about 50% more than the PB12-Plus over the more common bass regions.
    The PB12-Plus also opens up the possibility of nicer finish options (for more $$), along with a PEQ control. The PEQ is a single-band parametric equalizer with three controls (frequency, cut, bandwidth) that allows the user to reduce the severity of a room-induced peak in the frequency response.
    The PB12-NSD/2 is larger and heavier than the PB12-Plus, and only comes in textured black, and there is no PEQ option. While more utilitarian in nature, it's the performance enthusiast's subwoofer of choice in the $1,000 price bracket.********
    Thank you for your time and help! You have quite the following on Polk Audio’s forum sight!
    ********Great bunch of guys over there - I've got over 3000 posts myself put don't visit there too often anymore (just not enough time in the day). **********
    Regards,
    David K.
    Stuff...
    RTi12's - front
    CSi5 - center
    FXi3's - surrounds
    RTi4's - surrounds
    Denon 3805
    edited January 2007
    Does this really matter if one of the three ports is plugged? I wouldn't think so.
    Sounds to me like the NSD/2 is actually the better woofer here. Might not hit just quite as low as the Plus but above 23 Hz, 50% more output?!? That's quite a bit to me!!!
    Does anybody have experience with this PEQ control? Is it a MUST have on a sub? Interesting.
    I'm leaning toward the NSD/2 now. Seems it would be an all around better sub for me!
    He obviously doesn't know jack about this site ;)
    Stuff...
    RTi12's - front
    CSi5 - center
    FXi3's - surrounds
    RTi4's - surrounds
    Denon 3805
    edited January 2007
    What Ed and other SVS staffers seldom address is the SQ difference mainly because it's subjective. The Plus delivers a more defined sound and in room extention in 16hz tune is around 13-14hz. However, the Plus just can't fill a larger room and will go into distress if pushed too hard. The /2 subs can handle the 4000^3 + rooms with plenty of headroom. In smaller rooms they produce gut busting pressurization. If you really want to feel the bass and have the room, the /2 subs are the way to go. If you're in a moderate room, you'll get plenty of bass from a single Plus with, IMO, better sound quality(than the NSD) and a tad more extention. If you opt for the PEQ (premium finish only) you can smooth out a peak for flatter FR. This works very well for alot of folks, however, it's not designed to dig out a null which can only be corrected through placement and room treatment.
    Combo rig:
    SDA 1C, CS400i, SDA 2B
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
Welcome!
Welcome!
