Looking for SRS2 crossover info
jcaut
jcaut Posts: 1,849
edited December 2006 in Vintage Speakers
I'm thinking about some crossover upgrades for my SRS2's. They have the blade/blade cable and no bi-wire capability. Does anyone have a schematic or at least a list of the values of caps and resistors I'd need? I searched and found a thread detailing some crossover upgrades for SRS2's, but the were the later models with the four binding posts and I figure mine are different.
Thanks,
Jason
Post edited by jcaut on
    F1nut Posts: 51,686
    This is for one crossover.
    (3) 2.7 ohm
    (1) 3.5 ohm
    (1) 750pF
    (1) 4.4uF
    (1) 12uF
    (2) 34uF
    (1) 55uF
    (1) 130uF
    Edit to eliminate any confusion.
  • schwarcw
    schwarcw Posts: 7,358
    Here ya go! Courtesy of Darqueknight's SDA Compendium Vol. 2. I recommend that you PM him and buy one.
    Carl
  • jcaut
    jcaut Posts: 1,849
    Thanks Jesse, Carl and Raife. I DO need to get a copy of that SDA compendium. I'll put that on my list.
    Jason
  • DarqueKnight
    DarqueKnight Posts: 6,765
    The resistor just after the polyswitch is 3.5 ohms.
    There capacitor above the 130 uf capacitor is 55 uF.
  • ben62670
    ben62670 Posts: 15,969
    Buy The Book you will not be disappointed. Anyone who enjoys any SDA/SRS should have this book. Anyone thinking of purchasing any of the same should also purchase this book before investing in said speakers.
    Enjoy Ben
    Ben
