I Need Amp Help!
MIwrestler
I have the db690's and the db212-2. I want to know how much power i need for them. I want good amps, but not ones that will empty my bank account. I dont mind buying off ebay to get a good price either.
Post edited by MIwrestler on
You can actually look up the specs on your gear in the products section, under car audio.Alpine: CDA-7949
Alpine: PXA-H600
JL Audio: 10W6v2 (x2)
KnuKonceptz
Second Skin -
700 RMS for the subs and Id go with 75 RMS for the 690's.
As far as which amp, pick whichever one meets your budget, size and appearance requirements.polkaudio sound quality competitor since 2005
hey thanks alot guys. I think im gunna go with those kickers. i found the 750 for $200 and the 200 for $65. Thanks alot Macleod you've been a huge help.
Be careful if you found them off Ebay or some other rip off dealer. You never know what youre getting. The good thing about Sounddomain is that theyre authorized dealers so you know youre getting brand spankin' new in box equipment with the manufacturers blessings and warranty.polkaudio sound quality competitor since 2005
You could go check out Kicker's site for authorized dealers. Some sell Kicker remanufactured products (B-stock). This will allow you to have a Kicker warranty, not as long as the regualar one, but some warranty is better than no warranty.Alpine: CDA-7949
Alpine: PXA-H600
KnuKonceptz
Second Skin
