I Need Amp Help!
MIwrestler
MIwrestler Posts: 12
edited December 2006 in Car Audio & Electronics
I have the db690's and the db212-2. I want to know how much power i need for them. I want good amps, but not ones that will empty my bank account. I dont mind buying off ebay to get a good price either.
Post edited by MIwrestler on
  • 1996blackmax
    1996blackmax Posts: 2,436
    You can actually look up the specs on your gear in the products section, under car audio.
    Alpine: CDA-7949
    Alpine: PXA-H600
    JL Audio: 10W6v2 (x2)
    KnuKonceptz
    Second Skin
  • MacLeod
    MacLeod Posts: 14,358
    700 RMS for the subs and Id go with 75 RMS for the 690's.
    As far as which amp, pick whichever one meets your budget, size and appearance requirements.
  • MIwrestler
    hey thanks alot guys. I think im gunna go with those kickers. i found the 750 for $200 and the 200 for $65. Thanks alot Macleod you've been a huge help.
  • MacLeod
    Be careful if you found them off Ebay or some other rip off dealer. You never know what youre getting. The good thing about Sounddomain is that theyre authorized dealers so you know youre getting brand spankin' new in box equipment with the manufacturers blessings and warranty.
  • 1996blackmax
    You could go check out Kicker's site for authorized dealers. Some sell Kicker remanufactured products (B-stock). This will allow you to have a Kicker warranty, not as long as the regualar one, but some warranty is better than no warranty.
    Alpine: CDA-7949
    Alpine: PXA-H600
    KnuKonceptz
    Second Skin
