dvd plus minus divided by r - 101
RuSsMaN
Ok, I need a quick dvd recordable 101.
I got a Samsung dvd recorder, and it says it can 'do' dvd-r and dvd-rw. What is what, ie recordable, re-recordable? What is dvd+r?
Post edited by RuSsMaN on
DVD+R and DVD-R are exactly the same only different formats......which are exactly the same. They are interchangeable with a few very very rare exceptions. You'll know because your recorder will give you fits. I personally ahve never known anyone that has had any trouble. I use the +R's and -R's interchangeably without any difficulty whatsoever.
DVD-RW are re-writeable and may not be compatible with other players. Mostly they are, but sometimes the RW's give fits in machines other than what they were recorded on. I wouldn't use RW's for archiving purposes just because if you replace the machine they were originally recorded on they may not be compatible with a different machine.
stay away from the DVD-RW to many incompatibility problems with players..
DVD+ and DVD- are the most user friendly. I don't know the difference. but in my bottom of the line DVD player. both work just fine.PolkFest 2012, who's going>?
danger boy wrote:stay away from the DVD-RW to many incompatibility problems with players..
RW's are fine if you use them in the player they are recorded in, ie; recording TV shows, etc. They are made to be written over and over. But as DB says they can be incompatiable across other players and thus can be unreliable for stuff you've recorded and you want to keep permanetly.
heiney9 wrote:RW's are fine if you use them in the player they are recorded in, ie; recording TV shows, etc. They are made to be written over and over. But as DB says they can be incompatiable across other players and thus can be unreliable for stuff you've recorded and you want to keep permanetly.
true dat.. plus with the low cost of burnable DVD's.. why risk putting anything important on a RW disc?PolkFest 2012, who's going>?
PolkThug wrote:Eff +R, -R is the standard of the DVD Forum.
Whatever..........I use both (whatever is on sale) either will get the exact same result. They are both DVD standard."Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul! -
try a little google you lazy ****Dodd - Battery Preamp
ADS 1230 - Polk SDA 2B
Crown K1 - Subwoofer amp
Outlaw ICBM - crossover
Beringher BFD - sub eq
"I've always been mad, I know I've been mad, like the most of us have...very hard to explain why you're mad, even if you're not mad..." -
I didn't know the difference either, but the DVD burner in my PC will only work with the +. It is identified as a DVD+RW when I check it's properties under my computer. I tried to use the DVD-R and it didn't work.
So, check your drive first.Signature goes here -
Thanks guys, I've got a 5-pack of dvd-r to get started. Now I can record Grey's Anatomy for her to watch at her lesiure, and I'm no longer forced into that **** whipping.
Russ, F google, I can get everything I need right here.
Cheers,
RuSsMaN wrote:Thanks guys, I've got a 5-pack of dvd-r to get started. Now I can record Grey's Anatomy for her to watch at her lesiure, and I'm no longer forced into that **** whipping.
Cheers,
Russ
Why on earth would you want to record Grey's Anatomy?!? I love that show and would be thrilled to have her watch it with me :eek: ."Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul! -
FWIW I use all -r be it dvd or cd.
My bro was given some +r dvd for xmas and they do not work on his xbox. Now I know Russman, you're not about to watch or have your girl watch Grey's on your Xbox, but as mentioned earlier there are some issues with +R. -
Russ, good choice with the -R discs. Buy a lotto ticket today. These are the most compatible with all DVD drives including older ones, aside from commercially pressed discs. I have an old Panny that chokes with +R, +RW or +R DL (Dual Layer). There is a tweak though.
4.7 Gigabytes
-R (write once) and -RW (re-writable) are older formats than
+R (write once) and +RW (re-writable)
I still have my first -R/-RW recorder from 1997 which finishes in a hot 45 minutes.
Most but not all recorders built in the last few years supports +/-R and +/-RW. Some support +R DL (Dual Layer).
8.5 Gigabytes
+R DL (Dual Layer) came out after +/-R and can store your choice of more time or more quality.
If you record something from TV or a camcorder to your DVD recorder and use +R or +RW discs, chances are they will not play on Grandma's DVD player. The +R formats came out after -R so older players (including xbox1) will not recognize these discs as DVD's.
There is a software tweak you can do with some DVD recorders called bitsetting. This allows you to play +R, +RW, or +R DL (Dual Layer) discs on the oldest of DVD players and your xbox1.
http://www.signvideo.com/btst-d.htm
http://www.booktypefaq.com
http://www.cdfreaks.com/reviews/Increased-compatibility-DVD-bitsetting.html
http://www.cdfreaks.com/reviews/Why-DVDRW-is-superior-to-DVD-RW.html
A bitsetting software may exist for your drive. Google is your friend. Learn it, know it, live it.
As far as reliability goes, the two details I have found most important are (1) the brand of blank disc and (2) the software. Verbatim discs and RecordNow software rank very high. I stay away from white van and store brand discs. -
friggen alligators I cant believe it!!!!!:D
almost had me Russ.
RT1 -
I concur, quality media is a must for DVD recording!
Two thumbs up for Verbatim!
Btw..Verbatim DVD+R DL play great in the Oppo!2 Channel:
Amp/Parasound Halo A23
Pre/Carver C-1
Tuner/Carver TX-11a
CDP/Jolida JD 100A
Turntable/AR XB-Shure V15 III
