dvd plus minus divided by r - 101
RuSsMaN
RuSsMaN Posts: 17,985
edited December 2006 in Electronics
Ok, I need a quick dvd recordable 101.
I got a Samsung dvd recorder, and it says it can 'do' dvd-r and dvd-rw. What is what, ie recordable, re-recordable? What is dvd+r?
Post edited by RuSsMaN on
    heiney9 Posts: 25,504
    DVD+R and DVD-R are exactly the same only different formats......which are exactly the same. They are interchangeable with a few very very rare exceptions. You'll know because your recorder will give you fits. I personally ahve never known anyone that has had any trouble. I use the +R's and -R's interchangeably without any difficulty whatsoever.
    DVD-RW are re-writeable and may not be compatible with other players. Mostly they are, but sometimes the RW's give fits in machines other than what they were recorded on. I wouldn't use RW's for archiving purposes just because if you replace the machine they were originally recorded on they may not be compatible with a different machine.
  • danger boy
    danger boy Posts: 15,722
    stay away from the DVD-RW to many incompatibility problems with players..
    DVD+ and DVD- are the most user friendly. I don't know the difference. but in my bottom of the line DVD player. both work just fine.
    PolkFest 2012, who's going>?
    RW's are fine if you use them in the player they are recorded in, ie; recording TV shows, etc. They are made to be written over and over. But as DB says they can be incompatiable across other players and thus can be unreliable for stuff you've recorded and you want to keep permanetly.
  • danger boy
    true dat.. plus with the low cost of burnable DVD's.. why risk putting anything important on a RW disc?
  • PolkThug
    PolkThug Posts: 7,532
    Eff +R, -R is the standard of the DVD Forum.
    Whatever..........I use both (whatever is on sale) either will get the exact same result. They are both DVD standard.
    http://en.wikipedia.org/wiki/DVD_recorder
    -R was actually originally used in computer based burners
  • hoosier21
    hoosier21 Posts: 4,420
    try a little google you lazy ****
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
  • seo
    seo Posts: 305
    I didn't know the difference either, but the DVD burner in my PC will only work with the +. It is identified as a DVD+RW when I check it's properties under my computer. I tried to use the DVD-R and it didn't work.
    So, check your drive first.
    Signature goes here
  • RuSsMaN
    Thanks guys, I've got a 5-pack of dvd-r to get started. Now I can record Grey's Anatomy for her to watch at her lesiure, and I'm no longer forced into that **** whipping.
    Russ, F google, I can get everything I need right here.
    Cheers,
    Russ
    Cheers,
    Russ
    Why on earth would you want to record Grey's Anatomy?!? I love that show and would be thrilled to have her watch it with me :eek: .
  • Willow
    Willow Posts: 11,257
    FWIW I use all -r be it dvd or cd.
    My bro was given some +r dvd for xmas and they do not work on his xbox. Now I know Russman, you're not about to watch or have your girl watch Grey's on your Xbox, but as mentioned earlier there are some issues with +R.
  • Polk65
    Polk65 Posts: 1,405
    Russ, good choice with the -R discs. Buy a lotto ticket today. These are the most compatible with all DVD drives including older ones, aside from commercially pressed discs. I have an old Panny that chokes with +R, +RW or +R DL (Dual Layer). There is a tweak though.
    4.7 Gigabytes
    -R (write once) and -RW (re-writable) are older formats than
    +R (write once) and +RW (re-writable)
    I still have my first -R/-RW recorder from 1997 which finishes in a hot 45 minutes.
    Most but not all recorders built in the last few years supports +/-R and +/-RW. Some support +R DL (Dual Layer).
    8.5 Gigabytes
    +R DL (Dual Layer) came out after +/-R and can store your choice of more time or more quality.
    If you record something from TV or a camcorder to your DVD recorder and use +R or +RW discs, chances are they will not play on Grandma's DVD player. The +R formats came out after -R so older players (including xbox1) will not recognize these discs as DVD's.
    There is a software tweak you can do with some DVD recorders called bitsetting. This allows you to play +R, +RW, or +R DL (Dual Layer) discs on the oldest of DVD players and your xbox1.
    http://www.signvideo.com/btst-d.htm
    http://www.booktypefaq.com
    http://www.cdfreaks.com/reviews/Increased-compatibility-DVD-bitsetting.html
    http://www.cdfreaks.com/reviews/Why-DVDRW-is-superior-to-DVD-RW.html
    A bitsetting software may exist for your drive. Google is your friend. Learn it, know it, live it.
    As far as reliability goes, the two details I have found most important are (1) the brand of blank disc and (2) the software. Verbatim discs and RecordNow software rank very high. I stay away from white van and store brand discs.
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    friggen alligators I cant believe it!!!!!:D
    almost had me Russ.
    RT1
  • Roy Munson
    Roy Munson Posts: 886
    I concur, quality media is a must for DVD recording!
    Two thumbs up for Verbatim!
    Btw..Verbatim DVD+R DL play great in the Oppo!
    2 Channel:
    Amp/Parasound Halo A23
    Pre/Carver C-1
    Tuner/Carver TX-11a
    CDP/Jolida JD 100A
    Turntable/AR XB-Shure V15 III
