Technical Assistance
hearingimpared
hearingimpared Posts: 21,136
edited December 2006 in The Clubhouse
Customer Service (CS) Rep.: "Yes, Ma'am, how may I help you today?"
Customer: "Well, after much consideration, I've decided to install LOVE. Can you guide me through the process?"
CS Rep. : "Yes, I can help you. Are you ready to proceed?"
Customer: "Well, I'm not very technical, but I think I'm ready to install now. What do I do first?"
CS Rep. : "The first step is to open your HEART. Have you located your HEART ma'am?"
Customer: "Yes I have, but there are several other programs running right now. Is it okay to install while they are running?"
CS Rep. : "What programs are running ma'am?"
Customer: "Let's see, I have PAST-HURT.EXE, LOW ESTEEM.EXE, GRUDGE.EXE, and RESENTMENT.COM running right now."
CS Rep. : "No problem. LOVE will gradually erase PAST-HURT.EXE from your current operating system. It may remain in your permanent memory, but it will no longer disrupt other programs. LOVE will eventually overwrite LOW-ESTEEM.EXE with a module of its own called HIGH-ESTEEM.EXE. However, you have to completely turn off GRUDGE.EXE and RESENTMENT.COM. Those programs prevent LOVE from being properly installed. Can you turn those off ma'am?"
Customer: "I don't know how to turn them off. Can you tell me how?"
CS Rep. : "My pleasure. Go to your Start menu and invoke FORGIVENESS.EXE. Do this as many times as necessary until GRUDGE.EXE and RESENTMENT.COM have been completely erased."
Customer: "Okay, done. LOVE has started installing itself automatically. Is that normal?"
Cs Rep. : "Yes. You should receive a message that says it will reinstall for the life of your HEART. Do you see that message?"
Customer: "Yes I do. Is it completely installed?"
Cs Rep. : "Yes, but remember that you have only the base program. You need to begin connecting to other HEARTS in order to get the upgrades."
Customer: "Oops. I have an error message already. What should I do?"
Cs Rep. : "What does the message say?"
Customer: "It says "ERROR 412 - PROGRAM NOT RUN ON INTERNAL COMPONENTS. What does that mean?"
Cs Rep. : "Don't worry ma'am, that's a common problem. It means that the LOVE program is set up to run on external HEARTS but has not yet been run on your HEART. It is one of those complicated programming things, but in nontechnical terms it means you have to "LOVE" your own machine before it can "LOVE" others."
Customer: "So what should I do?"
Cs Rep. : "Can you pull down the directory called "SELFACCEPTANCE"?"
Customer: "Yes, I have it."
Cs Rep. : "Excellent. You're getting good at this."
Customer: "Thank you."
Cs Rep. : "You're welcome. Click on the following files and then copy them to the "MYHEART" directory: FORGIVE-SELF.DOC, REALIZE-WORTH.TXT, and ACKNOWLEDGE-LIMITATIONS.DOC. The system will overwrite any conflicting files and begin patching any faulty programming. Also, you need to delete VERBOSE-SELF-CRITIC.EXE from all directories, and then empty your recycle bin afterwards to make sure it is completely and permanently gone erased."
Customer: "Got it. Hey! My HEART is filling up with new files. SMILE.MPG is playing on my monitor right now and it shows that PEACE.EXE, and CONTENTMENT.COM are copying themselves all over my HEART. Is this normal?"
Cs Rep. : "Sometimes. For others it takes a while, but eventually everything gets downloaded at the proper time. So, LOVE is installed and running. You should be able to handle it from here. One more thing before I go."
Customer: "Yes?"
Cs Rep. : "LOVE is freeware. Be sure to give it and its various modules to everybody you meet. They will share it with other people and then return some similarly sacred modules back to you."
Customer: "I will. Thanks for your help. By the way, what's your name?"
Cs Rep. : " You may call me the Divine Cardiologist, also known as The Great Physician, but most call me God. Many people feel all they need is an annual checkup to stay heart-healthy, but the Manufacturer suggests a schedule of daily maintenance for maximum efficiency. Put another way, keep in touch.
Post edited by hearingimpared on
  • brettw22
    brettw22 Posts: 7,623
    ummmmm............ok?
  • Refefer
    Refefer Posts: 1,280
    I take it you're religious hearingimpared?
    Lovin that music year after year.
    Main 2 Channel System
    Polk SDA-1B,
    Promitheus Audio TVC SE,
    Rotel RB-980BX,
    OPPO DV-970HD,
    Lite Audio DAC AH,
    IXOS XHA305 Interconnects
    Computer Rig
    Polk SDA CRS+,
    Creek Audio 5350 SE,
    Morrow Audio MA1 Interconnect,
    HRT Music Streamer II
  • mrbigbluelight
    mrbigbluelight Posts: 9,878
    Despite the previous bland reviews from "Siskel & Ebert" above, I thought that was quite nice, HearingImpaired. :)
  • shack
    shack Posts: 11,154
    icon14.gif - I know a couple of folks who desparately need this upgrade. I may need to send them a copy.
  • PolkThug
    PolkThug Posts: 7,532
    At least its better than all the true stories of God installing CANCER.EXE.
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    Excellent. We can all use a bit self-reflection now and then. Those without love in their life are truly lost.
    Never forget the sacrifices the significant people in your life made to help you get whereever you are, they were motivated by Love.
    RT1
  • hearingimpared
    Not religious, Spiritual, I try my best each day.
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    Nice I enjoyed it thank you for sharing Hearingimpared.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • audiobliss
    audiobliss Posts: 12,518
    Very nice, hearingimpared. Thanks for the good read.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    Klipsch RF-35, RB-51ii
    [Car Audio]
  • Ern Dog
    Ern Dog Posts: 2,237
    Great reminder. thanks
  • petrym
    petrym Posts: 1,912
  • Poee7R
    Poee7R Posts: 906
    This is great, ill have to forward it to a few people.
    Dave
    Once again we meet at last.
