Tube dampers...
Joey_V
Joey_V Posts: 8,600
edited December 2006 in 2 Channel Audio
Does anyone here know where to get a good set of tube dampers or atleast where on the net is there a store with a rather large collection of tube dampers?
I need some for my Cary 98 pre (6sn7 tubes x4)...
Thanks,
Joey
Post edited by Joey_V on
  • halo
    halo Posts: 5,616
  • beardog03
    beardog03 Posts: 5,550
    got mine on the bay
    got a variety pack !
    Parasound HCA-3500
    Cary Audio V12 amp (Jag Red)
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    MIT Shotgun S1 I/C`s
    AQ Black Thunder Sub Cables
    PS Audio Plus Power Cords
    :cool:
  • halo
    halo Posts: 5,616
    more eBay
  • dorokusai
    dorokusai Posts: 25,576
  • Gaara
    Gaara Posts: 2,415
    I second the herbie's recommendation.
  • Toka78
    Toka78 Posts: 192
    Herbie's 3rd-ed.
  • pearsall001
    pearsall001 Posts: 5,243
    Has anyone tried Mapleshade Tube Anchors?
  • george daniel
    george daniel Posts: 12,096
    herbies,,juan mo time :)
  • Early B.
    Early B. Posts: 7,900
    Just ordered me some herbies...
    "God grooves with tubes."
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    I prefer Herbie's on my gear that has exposed tubes. The Mapleshades damp more, at the expense of totally covering up the cool tube glow.
  • Joey_V
    Joey_V Posts: 8,600
    Thanks all!!!
  • Libertyc
    Libertyc Posts: 915
    I was checking them out in the catalog. Is there a rubber sleeve or somthing inside the anchor or just metal to glass?
    I like what Herbies sells and will try a set someday.
    My preamp came with rings like the ones on ebay.
  • dorokusai
    It's all metal.
