Tube dampers...
Joey_V
Does anyone here know where to get a good set of tube dampers or atleast where on the net is there a store with a rather large collection of tube dampers?
I need some for my Cary 98 pre (6sn7 tubes x4)...
Thanks,
Joey
Thanks,
Joey
Post edited by Joey_V on
HT: Samsung QN90B * Marantz NR1510 * Panasonic DMP-BDT220 * Roku Ultra LT * APC H10 -
got mine on the bay
got a variety pack !Cary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Cary Audio V12 amp (Jag Red)
Jolida JD-100 CDP
SVS PC-Ultra Sub
MIT Shotgun S1 I/C`s
AQ Black Thunder Sub Cables
PS Audio Plus Power Cords
:cool: -
more eBayAudio: Polk S15 * Polk S35 * Polk S10 * SVS SB-1000 Pro
Herbie's 3rd-ed.
Has anyone tried Mapleshade Tube Anchors?
Just ordered me some herbies...HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
I prefer Herbie's on my gear that has exposed tubes. The Mapleshades damp more, at the expense of totally covering up the cool tube glow.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
Thanks all!!!Magico M2, JL113v2x2, EMM, ARC Ref 10 Line, ARC Ref 10 Phono, VPIx2, Lyra Etna, Airtight Opus1, Boulder, AQ Wel&Wild, SRA Scuttle Rack, BlueSound+LPS, Thorens 124DD+124SPU, Sennheiser, Metaxas R2R
I was checking them out in the catalog. Is there a rubber sleeve or somthing inside the anchor or just metal to glass?
I like what Herbies sells and will try a set someday.
My preamp came with rings like the ones on ebay. -
It's all metal.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
