Ebay Carver TFM 35 - help me out here
  • Ron Temple
    Ron Temple Posts: 3,212
    edited December 2006
    Recieved the amp back today, calibrated and gave it a listen. The SDA effect is here in spades now, no distortion, a ton of headroom. Lots of listening goodness coming up.
    My only complaint is that Classic Carver used popcorn on the return pack. Got all over the house :mad: .
    Combo rig:
    SDA 1C, CS400i, SDA 2B
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • snow
    snow Posts: 4,358
    nice amp i use a carver tfm-35x to push my sda srs 1.2 tls and my ears give up long before the amp does. not sure what he diffrence is if any between the tfm-35 and 35x versions are. i seen the pic that was posted looked like mine. REGARDS SNOW
  • Ron Temple
    You've got that fancy THX logo ;) . From some of the guys from here that post over there...there's either no difference or there is in that the (X) amp was unmodded for the tube-like sound to meet THX specs. I don't know which. Either way...nice amps.
    Combo rig:
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
    Anyone on a budget should consider carver amps.Good value all around and won't cost an arm and a leg to fix if something were to happen.Enjoy!!
