Mono blocks V.S. Multi-Channel
MSALLA
MSALLA Posts: 1,602
edited December 2006 in Electronics
Well, the wife has accepted we will have a set of lsi15's in the living room after the new year. So my question is what, if any are the benifits of using mono blocks over a multi channel amp? I was looking into a used Parasound but also thought about a set of Outlaw 2200's.
Michael
Samsung 50" HD DLP
Yamaha RX-V2500
(2) Outlaw 200
Adcom GFA 555
Sony BDP300
Denon 2900 DVD
Lsi9's mains
Lsi7's rear
Lsic center
12.1 SVS driver in 4.53 cuft. tube
Harmony 880
Post edited by MSALLA on
  • bert26
    bert26 Posts: 320
    Hi -
    Not sure that I am right on this, but I would suspect that the monos would give you more power output available indpendent of the channel, and more power available to the amplification section of the unit. I am sure I am oversimplifing things - someone will chime in here with the straight dope eventually.
    Cheers!
    Chris
    HT Rig
    Polk SDA SRS 2.3tl - Anthem 2 SE
    Polk CSi5 - Adcom 555
    Polk Monitor 30 - HK DPR1005
    SVS PB12 ISD/2
    Denon DCD-1500II
    Sony SXRD 60"
    ShengYa CS-10
    Basement Rig
    Polk SDA SRS2
    Carver 1.5t
    Carver C2
    Technics SLD202
    Some Other Sony DVD/CDP
  • Early B.
    Early B. Posts: 7,900
    Get the Parasound, maybe an HCA 1200 or 1500. IMO, the Parasound sounds better than the Outlaw monos.
    "God grooves with tubes."
  • Systems
    Systems Posts: 14,872
    The mono blocks will have a dedicated power supply for the one channel were as many of the multi channel units share a single supply among channels.There are some multi ch units that have a supply for each channel like Bryston's 6B and 9B but those extra transformers don't come cheaply.
    Testing
    Testing
    Testing
  • venomclan
    venomclan Posts: 2,467
    Ditto, the Parasound will be a more musical amp than the Outlaws.
  • Gaara
    Gaara Posts: 2,415
    You also don't have to worry about cross talk with mono amps.
  • MSALLA
    MSALLA Posts: 1,602
    Cross talk?
    Michael
    Samsung 50" HD DLP
    Yamaha RX-V2500
    (2) Outlaw 200
    Adcom GFA 555
    Sony BDP300
    Denon 2900 DVD
    Lsi9's mains
    Lsi7's rear
    Lsic center
    Harmony 880
  • zombie boy 2000
    zombie boy 2000 Posts: 6,641
    Basically, when the left channel signal leaks into the right channel.. or visa versa. As a result, you may find yourself with a confused soundstage with certain instruments and/or vocals losing focus on a recording.
  • sickicw
    sickicw Posts: 456
    the benifits of a mono vs multi channel really depend on what models you are talking about. yes, a mono block might have a dedicated power supply, but most multi channels have large energy storing transformers. I guess it depends on what your needs are. check this amp out....
    http://www.audioadvisor.com/prodinfo.asp?number=VISP331
    also im gonna start a seperate post about this amp.
    Speakers: LSi9 x 2, LSic, LSiFX x 2, Velodyne HGS-15
    Amps & Power: Rockford Fosgate T8004 x 3, Cascade Audio APS-55 power supplies x 5, and 1 farad capacitor.
    Electronics: Denon 3806, Toshiba HD-A1, & Sony KDL46XBR2
    Accessories: Anti-IC interconnects, 8 Mondo Traps from Realtraps, and Salamander furniture.
    Check out the Butlers also.Can be had on the used market for around 1500.
    250 W at 8 ohm 400 w into 4 ohm.Very musical and gutts for HT.6sn7gt tubes.
  • Ferres
    Ferres Posts: 310
    If you can get a pair of Parasound HCA 1200II's you can use them like monoblocks with one amp per channel, bi-wiring the lsi's.
    Gear: Rotel RC 1082, Rotel RSP 1068 pre/pro, Rotel RMB1077 amp, Cayin CDT 15a CD player, S301 bluray.
    Speakers: Tannoy DC sensys speakers, Paradigm Servo15 Sub, Velo Spl-1500r
    Conditioner: Isotek :D
