Musical Fidelity X-10v3 Tube Buffer.... opinions?
Joey_V
Joey_V Posts: 8,600
edited December 2006 in 2 Channel Audio
I've been reading a lot about this great (or so it seems) product... it seems to impart a bit more tube flavor to the sound while providing an easier load for whichever components it is next to.
I was thinking.... my parents are looking to get me something for Christmas and I'm kinda stuck....
Do any of you guys have any experience with this guy? I was thinking of putting this between the SB3 and the Cary 98 preamp.
Retail is $399 so it's not too bad on the wallet.
Thanks as usual,
Joey :)
Post edited by Joey_V on
  • Joey_V
    Joey_V Posts: 8,600
    Thing is, I was thinking that maybe the vocals could use just a hint more weight... and I always welcome any improvement in vocal imaging so I'm all for it.
    Only thing is, I was also thinking of getting a DAC and I wasnt sure if I should just focus on the DAC (like a PS Audio Digital Link III DAC or the Benchmark DAC1 or the MF XDAC)...
    Then again, I am in the process of tube-rolling the Cary with some Sylvania 6SN7GTB tubes....
    AhhhH... so much to think about! :p
    Joey
  • Early B.
    Early B. Posts: 7,900
    If you already have tube gear, why are you considering adding a tube buffer?
    "God grooves with tubes."
  • zombie boy 2000
    zombie boy 2000 Posts: 6,641
    There are couple on the 'gon for around $250.
    As for DAC's on the cheap, have you considered Pacific Valve?
    http://www.pacificvalve.us/NOSDACS.html
    $150 for the Lite Audio DAC
    $220 for the modded version of same.
    The latter has gotten some fairly solid reviews on other forums.
  • ND13
    ND13 Posts: 7,601
    I've heard nothing but good things about these.
    Use the search feature..there has been several threads on that piece of gear.
    "SOME PEOPLE CALL ME MAURICE,
    CAUSE I SPEAK OF THE POMPITIOUS OF LOVE"
  • haimoc
    haimoc Posts: 1,031
    I agree with Early B. Why don't you get a power shampoo if you don't have one, yet.
  • cstpeter
    cstpeter Posts: 387
    Joey, I used one with my old setup...it gave my all-SS gear a hint of tubeyness. However, I don't think you need one with your Cary. Also, you would definitely want to get a PSU power supply to go along with it.
    Von Schweikert VR4-jr
    Valve Audio Predator
    Denon DVD-2900
    PS Audio Digital Link III w/Cullen Level IV Mods
    Pro-Ject Xpression w/Blue Point No. 2
    Graham Slee Special Edition 2
    PS Audio UPC-200
  • Ricardo
    Ricardo Posts: 10,636
    Christmas present...and you get to choose? How about a source?;)
    SOPA
  • zombie boy 2000
    Any source besides your Apple IIC.....:D
  • Joey_V
    Joey_V Posts: 8,600
    Between the DAC and the pre.... the tube buffer in the Cary is between the pre and the amp..
    I figured just a bit more tubes will push the Summits just that much better. I noticed that the Summits are far better at revealing downstream equipment than even the Strata Minis, so I'm sure I'll hear something with the X10v3.
    Chris,
    Yeah... I see that I might have to spring for the XPSU also... but that would be a springboard for the XDac....
  • Joey_V
    Joey_V Posts: 8,600
    That's the thing.. or a DAC... but I have to pay the difference.
    I was/am heavily considering the PS Audio Digital Link III Dac...
  • Joey_V
    Joey_V Posts: 8,600
    And remember, people who have tube pres dont necessarily get SS amps.... some pair it with more tubes.
    Also, tube Dacs, tube amps, tube buffers, etc...
  • Ricardo
    How will a DAC improve if the original source is not that good???:D :D:D
    seriously..why not get a tube CD player?
    SOPA
  • Joey_V
    Joey_V Posts: 8,600
    Nonono.... the CDP will be an Ayre of some sort.....
    But you see, I have a large FLAC collection that I will not get rid of, pretty much forever, so I need a DAC for the SB3. Then I will also require a CDP and a TT. Each has its own purpose.
    Joey
  • Joey_V
    Joey_V Posts: 8,600
    Ooohh... Musical Direct has the X10v3 for 299$..... ooooh.....
  • szhleppy
    szhleppy Posts: 325
    For that price, why not try it out? I got Early's a couple weeks ago and have been happy with it...all of my other gear is SS for now.
    tonyb Posts: 33,072
    Your not going to hear much useing it with the Cary.Use the money to upgrade your cables bro.Your current gear surpasses what the MF buffer is meant for.
  • amulford
    amulford Posts: 5,020
    Tony is right. With the level of gear you're currently running your not going to get any real benefits from a tube buffer. If it were me, given your position, I'd go for a tubed DAC. You will get the benefit of basically a tube buffer with it. I would try to get multiple inputs with it, so you can add to the system later down the road.
  • cstpeter
    cstpeter Posts: 387
    Joey, while I tend to agree with the above posts, I remind you that Music Direct is just a few blocks from your place (318 N. Laflin). Why not try it out and return it if you don't like it?
    By the way, I was in there over the weekend and they have a pair of Avantgarde Duo Omega horn speakers set up...drool.
    Denon DVD-2900
    PS Audio UPC-200
  • halo
    halo Posts: 5,616
    If it were me I'd go for the DAC and / or some stuff from Signal Cable (IC's, Speaker Cables, & AC Cables). Remeber Frank gives us Polkies a discount and you have a 30 day trial period (if you don't like them / don't hear a difference just ship them back - be sure to give them 50 - 100 hours to burn in). Guess the same trial period applies to the DAC - What've you got to lose :confused: Just my $.02 but I wouldn't bother with the tube buffer.
    F1nut Posts: 51,776
    Get some CABLES!!!
    tonyb Posts: 33,072
    F1nut wrote:
    Get some CABLES!!!
    'Nuff said!!
  • Joey_V
    Joey_V Posts: 8,600
    F1nut wrote:
    Get some CABLES!!!
    Yeah yeah yeah.... :p .
    BTW, how much does Frank discount for us Polkies?
    Joey
  • Joey_V
    Joey_V Posts: 8,600
    I think I'm going with a DAC first....
    Cables will be in the future....
    Thanks guys!
    I'll start another thread for your recommendations.
    Joey
    F1nut Posts: 51,776
    Ok, I'm just going to come out and say it. You're flat out going about this whole thing the wrong way. You've got some nice pieces of gear and you're choking the **** outta what they are capable of with those patch and lamp cords. In fact, I can't understand how you can judge how any of it really sounds with those cables and the FLAC you're running as a source. I'm not sure where you're getting your advice, but they are not doing you any favors.
    Your list should have 2 things on it for now, new source and new cables, that's it.
  • Joey_V
    Joey_V Posts: 8,600
    With all due respect, come over and listen to my system before judging it and what I hear, Jesse.
  • schwarcw
    schwarcw Posts: 7,358
    Joey,
    Your obviously a bright guy with a significant amount of scientific training. I am truly am at a loss why you would you would be so objectionable try another variable in you sound analysis evluation (which has significant discussion counterpoints in the scientific lieterature). I've had PH D. engineers working for me with 15 or more years of experience who I would have spanked and sent them back to the lab for this blatant oversight in their objective and experimental technicique. Take a good look at your approach.
    PS. I'm being critical as a friend. Step back from you plan and rethink you approach.
    Carl
  • halo
    halo Posts: 5,616
    30 day in home trial period in regards to the IC's, Speaker Cables, & Power Cables. What have you got to lose? Its like you are a stubborn child digging your heels in and for what? If you try the cables / IC's (I highly reccommend doing them together and at the same time allowing 50 - 100 hours for burn in) and don't notice a difference you'll have proved (to yourself - in the end that is all that matters) that cables & IC's make no difference and you can tell us all to buzz off. Until you do I think you are doing yourself no favors by sticking with the lamp cord and "stock" IC's. I happen to believe, from personal experience, that the cables and IC's make an overall improvement and that you'll come to the same conclusion once you try it for yourself.
    Frank offers us Polkies a 5% discount and free shipping.
    F1nut Posts: 51,776
    Joey, I've no need to hear your set up to know what you're missing. Been there, done that.
  • halo
    halo Posts: 5,616
    I agree with F1nut here also.
  • Joey_V
    Joey_V Posts: 8,600
    Ok... where is the money best spent if not on a DAC?
    Are we all in agreement with cables?
