No replacement parts!!! for monitor 11's
turbobusa65
turbobusa65 Posts: 105
edited December 2006 in Vintage Speakers
No 12" planar passive radiators for the r.t.a. 11!! What now? if I have to go through madisound or parts express I will need a cross over number, or important info like (RR/FR/FS/QMS/QES/QTS/VAS/internal demensions of speakers) and I dont know the answer to any of that! What,s the answer guru's? :mad: :mad: :(
Post edited by turbobusa65 on
  • RuSsMaN
    RuSsMaN Posts: 17,985
    Buy a set of speakers from this century?
    What's wrong with yours?
  • John in MA
    John in MA Posts: 1,010
    His passives are missing, someone removed them.
    I'm surprised Polk doesn't have them, usually they're pretty good about support for discontinued speakers.
  • turbobusa65
    :rolleyes: :mad: :mad:
  • RuSsMaN
    That sucks, keep watch on ebay, SDA/RTA are parted out all the time.
  • dorokusai
    dorokusai Posts: 25,626
    They haven't supported PR's in years. I used a pair of Peerless PR's in a pair of SDA's a long time ago, worked just fine.
  • turbobusa65
    Would'nt happen to remember the exact ones would you? model no#? anything? Thank's:(
  • dorokusai
  • turbobusa65
    dorokusai wrote:
    Thank you very much, anybody else?:)
  • turbobusa65
    R.T.A. 12a's b's and c's use the same PR, sw120's those would work also.;) I am shure someone here would know, just has'nt seen this yet!
  • dorokusai
    Your going to have to use your own skills with a measuring tape and a pencil to get the cabinet dimensions and volume specifics....this is not information that is available from Polk Audio.
    In regards to a aftermarket replacement PR, again you'll have to use your own judgement. I picked the Peerless because it was a drop in fit, was roughly matched in regards to specifications and the weighting of it was a best guess scenario but I didn't perceive any problems. The new owner of them loved them, case closed.
    It's time to put your thinking cap on, good luck.
  • turbobusa65
    Dorokusai, thank you for that input. That is exactly what I did! just got off the phone with a parts express tech, and they are on their way!! thank's again!:D
