DIY Bass Trap
tecmo04
tecmo04 Posts: 421
edited January 2007 in DIY, Mods & Tweaks
http://www.diy-home-theater-design.com/bass-trap-build.html
Im thinking about trying to build a bass trap. Anyone ever try this? Opinions as to if it will work?
Post edited by tecmo04 on
  • Systems
    Systems Posts: 14,872
    edited December 2006
    According to some acoustics experts that design will have no effect and is a waste of material.For a bass trap to work it must be absorbative ,that sonotube is just a reflector.However their are several inexpensive and easy to build bass traps designs.I will dig up the links and post them for you when I get a few minutes.
    Testing
    Testing
    Testing
  • Systems
  • unc2701
    unc2701 Posts: 3,587
    Yep, that sonotube won't do crap. The design GV links to is way better, but probably won't hit the standing wave frequencies most people have in their rooms.
    Look into slat helmholtz resonators, panel resonators, and if you can afford to lose about 3'-4' in your corners, the design as above.
    Of course the first step is an SPL meter and some test tones to see how bad your room is and where the problems are.
    Backburner:Krell KAV-300i
  • RuSsMaN
    RuSsMaN Posts: 17,985
    I wish it was that easy. (link in orig post)
  • Systems
    If you can afford to give up the corners of your room (this is were bass traps are most effective) Super Chunks are the Queen Mom of bass traps.http://www.bobgolds.com/TrapHarder/home.htm
    http://forum.studiotips.com/viewtopic.php?t=535
    Testing
    Testing
    Testing
  • tryrrthg
    tryrrthg Posts: 1,896
    This page is pretty much the standard for bass traps that I've seen around the forums. The cylinder trap is probably one of the most effective traps.
    http://www.geocities.com/jonrisch/basstrap.htm
    more details:
    http://www.geocities.com/jonrisch/a.htm
  • jm1
    jm1 Posts: 618
    I think that 'bass trap' would function more as a diffuser than a bass trap. An empty tube would only diffuse higher frequencies. Loading the tube with sand will increase the mass and make it full range diffuser. I imagine this should provide some benefit as it would break up standing waves by diffusing (scattering) the reflected sound. It will not provide any absorption of bass energy within your room.
    I found some of my posts on what I have completed for my room:
    DIY Tube Traps
    jmierzur & bass traps
    If you are not handy, try the quick and dirty corner traps on the Risch site to see what benefits this provides. You can also place DIY or purchased panels across the room corners to create a 'bass trap'.
    All truth passes through three stages. First, it is ridiculed, second it is violently opposed and third, it is accepted as self evident.
    Arthur Schopenhauer
  • tecmo04
    tecmo04 Posts: 421
    ive seen those. Is there any way to do this with out using insulation. Im not to thrilled on having isolation exposed in my house. Any thoughts?
  • jm1
    jm1 Posts: 618
    Are you referring to the quick and dirty traps? If so, you do not open the bundle to expose the insulation. Look for bundles without any rips or tears. If this is not possible, seal the bundle with tape. Clean the exterior and place in the desired location to determine if they provide any benefits. If you decide to keep the bundles, cover with some type of fabric to compliment the room decor or build a container for the bundle.
    Arthur Schopenhauer
  • SLOCOOKN
    SLOCOOKN Posts: 704
    edited January 2007
    Just more info and a good article.
    HTTP:www.ethanwiner.com/acoustics.html
    :eek: From the bottom it looks like a steep incline, From the top another down hill slope of mine.:mad: But I know the equilibrium's there!:cool: .."Faith No More" :D
    Sony cx985v (for now)
    BBE 482i
    B&K AVP 1030
    Adcom GFA 555 mk 2
    AudioQuest Crystal 2 spk wire
    Nordost RCA
    SDA 3.1 tl RD0 tweets
    Belkin pf60
    Carver TFM 55x
    Signal Analog 2 RCA
    AudioQuestType 4
    VMPS Original Tall Boy (Mega Woofers soon)
  • SLOCOOKN
    SLOCOOKN Posts: 704
    edited January 2007
    I have had it. Other than SVS I don't think anyone out there can agree on anything collectively as a group..hd vs. blue ray, sacd vs. redbook, Dlp vs. plasma vs. lcd, seperate dac vs. no seperate dac...NOW even on bass traps 705 vs. 703....AHHHHHHHHHHHHHHHHHHHHHHHHHHHHHH
    MAKE UP YOUR FLIPPIN" MINDS!!!!!!!!!!!!!..
    This is just amusing to me..I guess the old adage goes...Try it if ya like it that is just fine..
    BBE 482i
    B&K AVP 1030
    Adcom GFA 555 mk 2
    Nordost RCA
    Belkin pf60
    Carver TFM 55x
    Signal Analog 2 RCA
    AudioQuestType 4
  • Midnite Mick
    Midnite Mick Posts: 1,591
    edited January 2007
    Yeah, there is just no hope for us that don't know what the hell we are doing. I suggest flipping a coin.:)
    Mike
    Modwright SWL 9.0 SE (6Sons Audio Thunderbird PC with Oyaide 004 terminations)
    Consonance cd120T
    Consonance Cyber 800 tube monoblocks (6Sons Audio Thunderbird PC's with Oyaide 004 terminations)
    Usher CP 6311
    Phillips Pronto TS1000 Universal Remote
  • SLOCOOKN
    SLOCOOKN Posts: 704
    edited January 2007
    Mike
    You would need to find out what the right coin would be! :)
    and no one would agree on that either.
    BBE 482i
    B&K AVP 1030
    Adcom GFA 555 mk 2
    Nordost RCA
    Belkin pf60
    Carver TFM 55x
    Signal Analog 2 RCA
    AudioQuestType 4
  • Midnite Mick
    edited January 2007
    lol
    Would need a 3 sided coin for your display example as well.
    Mike
    Consonance cd120T
    Usher CP 6311
  • Systems
    edited January 2007
    I just finished these corner traps.They are cheap and easy to build and they are very effective.
    Testing
    Testing
    Testing
  • Midnite Mick
    edited January 2007
    What are they stuffed with?
    Mike
    Consonance cd120T
    Usher CP 6311
  • Systems
    edited January 2007
    Mike
    3" thick mineral wool.I cut pieces in a triangular shape and stacked them into the plywood frame.
    http://www.roxul.com/graphics/rx-na/canada_us/products/AFB/AFB-English-5-16-06.pdf
    Testing
    Testing
    Testing
  • Midnite Mick
    edited January 2007
    Interesting.
    And you have a little corner shelf. Is there an optimal size...etc. Did you get that idea online or did you do this on your own.
    Thanks,
    Mike
    Consonance cd120T
    Usher CP 6311
  • Systems
    edited January 2007
    Mike, That pic with the plywood is not a shelf but the bare frame before the wedges of mineral wool were added then it was covered with material.It just supports the insulation.
    As far as size goes the bigger the better.I got the idea from a commercial product but I made mine a bit smaller for WAF reasons.Mine are 40" tall and it spans 16" across.
    Testing
    Testing
    Testing
  • Midnite Mick
    edited January 2007
    The stuffing though is only on the inside is it not? One could still put something atop if one desired couldn't they?
    Just curious what kind of transparent material did you use?
    Thanks,
    Mike
    Consonance cd120T
    Usher CP 6311
  • Systems
    edited January 2007
    Yes Mike, the stuffing is only on the inside.Sure you could place something on the top and use it like an end table.Is that what you mean?I may put a solid wood top piece on mine at some point.I am not sure what the material I used is made of (possibly nylon or polyester),but it is easily stretched without bunching up and it is acoustically transparent.Any material that you can see light through or breathe through is fine.
    Fred
    Testing
    Testing
    Testing
  • tecmo04
    tecmo04 Posts: 421
    edited January 2007
    interesting. was that hard to build? total cost?
  • Systems
    edited January 2007
    Hi tecmo04,these are very easy to build.
    As far as costs ,I already had the insulation and the material left over from another acoustic panel project so I only needed to buy the 1/4 inch plywood for a total of $15 for two bass traps.I think the insulation was about $25 and that was enough for several units.The cover material was inexpensive.
    Testing
    Testing
    Testing
  • SLOCOOKN
    SLOCOOKN Posts: 704
    edited January 2007
    One thing you might consider as well. Flat panel may absorb more LF than a corner wedge placed directly in the corner. You may not need as much wood and lower the cost.
    That said, GV#27 your traps look great!
    I am going to build mine over the next 2 months. I am going to use white fabric and have them airbrushed with pictures or designs...not sure yet.
    My plan is as follows...so far....1x6 frames that are 2' wide at the top and 4' tall...if I can find mineral wool great....if not 705 or 703...6 panels I think..
    BBE 482i
    B&K AVP 1030
    Adcom GFA 555 mk 2
    Nordost RCA
    Belkin pf60
    Carver TFM 55x
    Signal Analog 2 RCA
    AudioQuestType 4
  • Systems
    edited January 2007
    Thanks SLOCOOKN, According to the experts I consulted ,the wedge shape with its increased insulation thickness will actually be more effective at lower frequencies than a flat panel with an air space behind it.The thicker the insulation the better.As far as cost it was cheaper and easier to build these corner traps than it was to build my regular panels.
    Testing
    Testing
    Testing
  • SLOCOOKN
    SLOCOOKN Posts: 704
    edited January 2007
    Would you suggest that I am on the right construction path with my panels?
    BBE 482i
    B&K AVP 1030
    Adcom GFA 555 mk 2
    Nordost RCA
    Belkin pf60
    Carver TFM 55x
    Signal Analog 2 RCA
    AudioQuestType 4
  • Systems
    edited January 2007
    Yes that type of trap can work very well also.Most build them 2'x4' and at least 4" thick.The OC 703 or 705 is excellent for this purpose. I used mineral wool because the OC 703 is not sold in Canada.
    Here is how I did mine.
    Testing
    Testing
    Testing
  • SLOCOOKN
    SLOCOOKN Posts: 704
    edited January 2007
    They look like maggies... :)
    Thanks for the pics! They look very nice..The end caps are a nice touch.
    I was thinking of using "chicken wire" to hep support the insulation...What do you think.
    BBE 482i
    B&K AVP 1030
    Adcom GFA 555 mk 2
    Nordost RCA
    Belkin pf60
    Carver TFM 55x
    Signal Analog 2 RCA
    AudioQuestType 4
  • Systems
    edited January 2007
    The OC stuff is semi rigid so it may not need any more support than the wooden frame and the material holding the front.But you could use chicken wire across the back for support.I added strips of 1/4'' hard board running from top to bottom to hold the insulation in.
    Testing
    Testing
    Testing
