Sub Location
apc
apc Posts: 779
Is it OK to locate a sub on top of an entertainment center? It is a pretty substantial piece of furniture in terms of weight.
Husband, Father, Son, Brother, Friend.
Post edited by apc on
  • Jim Shearer
    Jim Shearer Posts: 369
    edited December 2006
    I guess you could do that. Must be a modest size sub if you can put it up there. On a larger sub I would suggest keeping it on the floor to get maximum coupling to the room. But as long as the vibrations don't cause a problem w/ anything on the shelves, why not?
    Cheers, Jim
    A day without music is like a day without food.
  • apc
    apc Posts: 779
    It's a PSW202, so not very large.
  • whitetruk
    whitetruk Posts: 311
    i would get a bigger sub,
    then it would not be an issue,(keep it on floor)
    I thought it was fairly amusing also. The Polk Ogre doesn't always get 'it'
  • apc
    apc Posts: 779
    Sub is plenty for the small room it's in. Bigger isn't always better.;)
  • McLoki
    McLoki Posts: 5,231
    A quote often made by those with small subs... ;)
    Michael
    Edit - And while you can put a sub up there, I wouldn't just due to the vibration that may be passed on to the electronics or other breakables in your entertainment center.
  • apc
    apc Posts: 779
    Ohhhhh, I see. OK I admit a case of sub-envy. Perhaps there's a pill to compensate (as long as it doesn't last more than 4 hours).
  • SLOCOOKN
    SLOCOOKN Posts: 704
    As with the use of any sub. Please make sure no children are present during operation.
    :eek: From the bottom it looks like a steep incline, From the top another down hill slope of mine.:mad: But I know the equilibrium's there!:cool: .."Faith No More" :D
    Sony cx985v (for now)
    BBE 482i
    B&K AVP 1030
    Adcom GFA 555 mk 2
    AudioQuest Crystal 2 spk wire
    Nordost RCA
    SDA 3.1 tl RD0 tweets
    Belkin pf60
    Carver TFM 55x
    Signal Analog 2 RCA
    AudioQuestType 4
    VMPS Original Tall Boy (Mega Woofers soon)
