Sub Location
apc
Is it OK to locate a sub on top of an entertainment center? It is a pretty substantial piece of furniture in terms of weight.
Husband, Father, Son, Brother, Friend.
Post edited by apc on
I guess you could do that. Must be a modest size sub if you can put it up there. On a larger sub I would suggest keeping it on the floor to get maximum coupling to the room. But as long as the vibrations don't cause a problem w/ anything on the shelves, why not?
Cheers, JimA day without music is like a day without food. -
It's a PSW202, so not very large.Husband, Father, Son, Brother, Friend.
i would get a bigger sub,
then it would not be an issue,(keep it on floor)I thought it was fairly amusing also. The Polk Ogre doesn't always get 'it' -
Sub is plenty for the small room it's in. Bigger isn't always better.;)Husband, Father, Son, Brother, Friend.
A quote often made by those with small subs...apc wrote:Sub is plenty for the small room it's in. Bigger isn't always better.;)
Michael
Edit - And while you can put a sub up there, I wouldn't just due to the vibration that may be passed on to the electronics or other breakables in your entertainment center.Mains.............Polk LSi15 (Cherry)
Ohhhhh, I see. OK I admit a case of sub-envy. Perhaps there's a pill to compensate (as long as it doesn't last more than 4 hours).Husband, Father, Son, Brother, Friend.
As with the use of any sub. Please make sure no children are present during operation.:eek: From the bottom it looks like a steep incline, From the top another down hill slope of mine.:mad: But I know the equilibrium's there!:cool: .."Faith No More"
Sony cx985v (for now)
BBE 482i
B&K AVP 1030
Adcom GFA 555 mk 2
AudioQuest Crystal 2 spk wire
Nordost RCA
SDA 3.1 tl RD0 tweets
Belkin pf60
Carver TFM 55x
Signal Analog 2 RCA
AudioQuestType 4
VMPS Original Tall Boy (Mega Woofers soon)
