jolida cdp and ei elite
Midnite Mick
I haven't listened to this player since the spring. I had been swapping around a couple of other cd players the last few days and this evening finally put some ei elite tubes in the jolida and gave it a spin. As soon as I gave it a whirl I was quite impressed. Much more open, more top end, more dynamic, with more resolution than I have ever heard from this player. More edge and glare as well but these are brand new tubes and need time to settle in.
I guess I should get to the point. I hear a constant ticking or like I am hearing the cd spinning. Is this Hydrophonics as I have not ever experienced this before? Are these tubes more prone to this. I have to make it clear however, that these are not the gold pins as they were not available from where I had ordered at the time. Other than the ticking I am actually taken aback at the presentation. I am now not sure which player was better as I was demoing the Consonance ref 2.2 tubed MKII player. hmmm
I know this has been discussed in depth and this is a very popular player amongst the Polkers. Do your ei elites do this as well?
Thanks,
Mike
Thanks,
Mike
Modwright SWL 9.0 SE (6Sons Audio Thunderbird PC with Oyaide 004 terminations)
Consonance cd120T
Consonance Cyber 800 tube monoblocks (6Sons Audio Thunderbird PC's with Oyaide 004 terminations)
Usher CP 6311
Phillips Pronto TS1000 Universal Remote
Consonance cd120T
Usher CP 6311
Post edited by Midnite Mick on
Hi Mike!
I think you mean microphonic. Flick your fingernail against the glass of the tube. If it has a ring, Your tube may be microphonic. You could very well have a tube gone bad, or something in the CDP electronics. I've had no trouble with the Ei's gold or no gold.Carl -
Yeah....hydrophonics is when you think you hear water dripping from your CDP
2 channel - Willsenton R8 tube integrated, Holo Audio Spring 3 KTE DAC, audio optimized NUC7i5, Windows 10 Pro/JRiver MC29/Fidelizer Plus 8.7 w/LPS and external SSD drive, PS Audio PerfectWave P3 regenerator, KEF R3 speakers, Rythmik F12SE subwoofer, Audioquest Diamond USB cable, Gabriel Gold IC's, Morrow Audio SP5 speaker cables. Computer - Windows 10/JRiver, Schiit Magni 3+/Modi 3+, Fostex PMO.4n monitors, Sennheiser HD600 headphones -
Carl hit it, you've got a microphonic tube or two.Political Correctness'.........defined
President of Club Polk -
as waitin for my jolida,stock form,does micrphonic tube happen often???I thought it was fairly amusing also. The Polk Ogre doesn't always get 'it'
lol. I knew it wasn't the right term...but just couldn't think of it. It was either that or hooked on phonics...just wasn't sure.
When I ordered them I ordered them as a balanced pair. I guess they don't take this into consideration then.
Thanks,
MikeModwright SWL 9.0 SE (6Sons Audio Thunderbird PC with Oyaide 004 terminations)
Consonance cd120T
Usher CP 6311
Phillips Pronto TS1000 Universal Remote -
So I started everything up this morning and now it is gone. Could it have been the result of how the cd was sitting in the carriage?
Consonance cd120T
Usher CP 6311
I've had a tube "heal" itself. Interesting phenomena. I heard some strange high pitched "whistle" in certain music passages. It was not very prominent in the music, but definitely there. I switched tube, it went away. Then put the old tube back in, and it was gone. Go figure.
CarlCarl -
The Ei Elite gold pins sound great in the Jolida! As per Jesse's recommendation I tried a pair and a couple of others including a some GE Jan WA's. The Ei's really start to sound even better after about 10 hours. I've read that 5150's are a good match for the Jolida also..does anyone have an opinion on them?2 Channel:
Amp/Parasound Halo A23
Pre/Carver C-1
Tuner/Carver TX-11a
CDP/Jolida JD 100A
Turntable/AR XB-Shure V15 III
