SDA ll
acerjac
acerjac Posts: 28
edited December 2006 in Vintage Speakers
New to club polk and to SDA's. Just bought a pair from ebay for 244.00. When I received them they needed a little work from damage during shipping. Got them working and wow!!! I am hooked on SDA's. I have a pair of Mon 5B's, RTA 15TL's, and a pair of 4a's. The SDA's sound incredible. The interconnect cable I got from Polk works well but the connection in back is loose on both speakers. It is the blade style. Any suggestions?? Also any suggestions on tweeter replacments?
Mark
Post edited by acerjac on
  • ben62670
    ben62670 Posts: 15,969
    I just got a set of sd2's on ebay also, and I have the RTA15tl's too.
    How did I do?
    Thanks Ben
    Ben
  • schwarcw
    schwarcw Posts: 7,358
    Congrats Acerjac and Welcome to the Club Polk Forums! You've got a great pair of speakers! I hope you and ben62670 didn't buy the same pair! Congrats and good luck!
    Carl
  • acerjac
    acerjac Posts: 28
    You did better than I did. I looked at the set you purchased and they are in better shape then mine. I had to put some money into the speakers I purchased. One of the 6.5's was blown. Good job!
    Mark
  • ben62670
    There is a silk dome that the guys here talk about as an upgrade. The old sl2500's are fairly sharp and fatiguing after a while. I am not sure how the sl2000's sound, because I haven't recieved mine yet! Look into replacing the caps in the crossovers too. I hear that helps a lot. What are you driving them with?
    Enjoy... Ben
    Ben
  • acerjac
    acerjac Posts: 28
    Right now I am using a NAD T753 to power them. Its ok but they would sound better with more power. I also have an old HK PA 2400 (175 watts a channel) that I use to power the 15's and they sound alot better with it. I will be getting another amp later on. I have heard about the silk tweeters and have them in the 15 TL's. They do sound good.
