Jolida JD-202 Integrated Tube Amplifier
dorokusai
dorokusai Posts: 25,638
edited December 2006 in For Sale (FS) Classifieds
Jolida JD-202A Integrated Tube Amplifier - Black/Silver - 9/10 - *SOLD to Riglehart*
This is a cool integrated amplifier that I've played with for a few hours. The unit had low hours to begin with but I had to get my ear on it for awhile. It's an original owner unit and is pristine, not a mark on it, as in MINT. The chassis is black with the end plates all brushed aluminum. It has gold tube sockets and a pretty **** end, also covered in gold.
It ran my Polk LSi15's with no issues.
Underwood HiFi has started to MOD these units so that's an option if you want something more hardcore.
It's sporting a matched pair of Electro-Harmonix 12AT7's on the front end, as one of the stock tubes was not testing great, so you get a BRAND NEW pair of MUCH better tubes. The EL34 and 12AX7 stage tubes are original and the unit was stock biased although you should re-bias it when you get it anyways.
Construction Details and Features:
Fully Integrated Stereo Amplifier: Input 350mV driving 40 watts, maximum 50 watts output.
Multiple Inputs: Front mounted selector switch-CD, Tuner and Aux (for TV, DVD Player, VCR or computer).
Custom Wound Audio Transformers with a core of German grain oriented silicon steel. 15th generation proprietary design. Secondary can be configured for a 4 ohm or 8 ohm load.
State of the Art Components: ALPS or Panasonic audio potentiometer, gold plated RCA input jacks, gold plated five way speaker connectors.
Low Feedback Design: Only 9 dB.
Technical Specifications:
Maximum Power Output: 60 W per channel at 8 ohms, 1KHz
Rated Output Power: 40 W per channel at 8 ohms, 30Hz to 80KHz
Frequency Response: (at 1 watt into 8 ohms) 7Hz to 140KHz + 3dB; 0dB at 1KHz
Bandwidth: 17Hz to 140KHz + 3dB; 0dB = 40 W 1KHz, 8 ohms
Distortion THD + N: Less than 1% at 30W output, 40Hz to 14KHz, 8 ohms
Circuit Type: Ultra Linear, Class AB1
Input Impedance: 100Kohms
Input Sensitivity: Max. 350mV at 1KHz for 40 watt output
Output Impedance: 4 ohms and 8 ohms
Negative Feedback: Less than 9 dB
Noise and Hum: 80dB below rated output.
Tube Complement: 2 matched pairs (4) of 6CA7/EL34 power output; 2 pcs. 12AX7A pre-amplifier, 2 pcs. 12AT7 power drivers.
Power Requirements: 110V-120 VAC 60Hz 120 watts-standby, 300 watts maximum (220 VAC 50Hz option).
Dimensions: 12.5 inches (30 cm) wide by 12 inches (31 cm) deep by 8.25 inches (21 cm) high.
Weight: 28 pounds (13 Kg) net, approximately 32 pounds (15 Kg) packaged.
Warranty: One year limited parts and labor. Six months or 500 hours whichever comes first on Jolida Tubes.
Bias Settings: 40 millivolts + 4 mV
Fuse: 110-120 VAC, 6.3 Fast Blo; 200-240 VAC, 3 Amp Fast Blo
Includes: Original box and packaging, original EL34/12AX7 tubes, original power cord and a brand NEW set of 12AT7 tubes w/ boxes.
Jolida JD-202A
Thanks for reading and if you have any questions, dorokusai@comcast.net
JJD202A530
Post edited by dorokusai on
  • audiobliss
    audiobliss Posts: 12,518
    Wow, she sure is a beauty.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    Klipsch RF-35, RB-51ii
    [Car Audio]
  • Shizelbs
    Shizelbs Posts: 7,433
    I'm drunk.
    Any chance in hell this would run my Amazings?
  • amulford
    amulford Posts: 5,020
    Maybe the ribbons...
    Nice...
  • dorokusai
    Shizelbs wrote:
    I'm drunk.
    Sure but it wouldn't be a good choice in regards to overall response.
  • criverajr
    criverajr Posts: 1,675
    Great unit, wish I were into tubes.
  • ND13
    ND13 Posts: 7,601
    It'll push SDAs just fine, though!!
    "SOME PEOPLE CALL ME MAURICE,
    CAUSE I SPEAK OF THE POMPITIOUS OF LOVE"
  • SLOCOOKN
    SLOCOOKN Posts: 704
    Now I wish I HAD bought thoes La Scalla's Nice equipment
    :eek: From the bottom it looks like a steep incline, From the top another down hill slope of mine.:mad: But I know the equilibrium's there!:cool: .."Faith No More" :D
    Sony cx985v (for now)
    BBE 482i
    B&K AVP 1030
    Adcom GFA 555 mk 2
    AudioQuest Crystal 2 spk wire
    Nordost RCA
    SDA 3.1 tl RD0 tweets
    Belkin pf60
    Carver TFM 55x
    Signal Analog 2 RCA
    AudioQuestType 4
    VMPS Original Tall Boy (Mega Woofers soon)
  • Shizelbs
    I get optimistic when I drink.
  • dorokusai
    This is the perfect Christmas or Chanuka gift for yourself....screw the kids.
  • Libertyc
    Libertyc Posts: 915
    Very nice. A great way to get into some good tubes on the cheap.
    Thinking...
  • dorokusai
    That's alot of nice tube glow as well :)
  • ND13
    ND13 Posts: 7,601
    Just be careful where you sit when in your assless chaps.:p
  • dorokusai
    Anyone? I dropped the price a few duckets if that helps. Thanks for looking either way.
  • riglehart
    riglehart Posts: 276
    I'll bite. How much shipped to 52241? I can use paypal or USPS money order. Was referred to you via a post in the 2-channel thread. I've never owned a tube amp.
    I tried to PM you but it said you weren't accepting them.
    robert.iglehart@prcnet.com
    Jolida Tube
    Polk 11T, 7, 5, 5jr, 4
    Standard equip not worth bragging about.
  • dorokusai
    Robert - The price is including shipping so your all set. I'll email you later tonight and thanks.
    I noticed the other thread and there's nothing cheap about this piece of gear....you'll LOVE it.
    Thanks Fred for remembering me :)
