New to form - Hi all - Help Best Install
tnholly
tnholly Posts: 2
A few quick questions to help with my new install.
1. Is Bi wiring really worth the effort?
If so what wire gauge difference should I use between
Low and high end
2. I am using only surround at present (monitor 40's)
Is it worth the investment for surround back?
Can I wire my rear monitor 40's for the surround back?
3. Based on my current set-up which PWS should I invest in (Polk of course).
I know I'll get good advice, and appreciate your welcome and help
THANKS
ONKYO TX-SR603X
DS-A2 iPod dock
Polk Monitor 70 - main
Polk Monitor 40 - surround
Polk CS1 - center
Polk PSW12
Post edited by tnholly on
  • polktiger
    polktiger Posts: 556
    edited December 2006
    I bi-wired my fronts using the a & b speaker outs last weekend, and I like the way it sounds. It is not night and day difference, but my hearing is not as good as it used to be. Since I went to the trouble to do it, I will leave it that way. While I am far from an expert, I think you will want to run the same gauge wire to each post (and remove the jumper) since you will really be powering high and low speakers independently.
    You would need to get another pair of speakers for rear surround. At the advise of others in the forum, I pulled the wires for them, but in all honesty I only pulled them since I was doing the regular surround wires at the same time. I have noticed that it makes a difference in some scenes, but it has not blown me away yet as a home theater "must do". In time as there is more 7 channel material having the extra wire will make a bigger difference.
  • Polkapops
    Polkapops Posts: 267
    You may want to look into an SVS sub. I learned about them on this
    forum. I, as well as many other members are EXTREMELY happy with
    the performance.
    HT & Music System:
    Receiver - Denon AVR-3805
    DVD/SACD Player - Denon DVD-2900
    Outlaw 770 amp
    Polk LSi 15's up front
    Polk LSiC center
    Polk LSi F/X surrounds
    SVS 16-46 PC+ Subwoofer
    Sony Wega KDF-50WE655
  • BaggedLancer
    BaggedLancer Posts: 6,371
    This may be going against the grain but depending on your budget if SVS is out of the question, my velodyne DLSR performs great. Comes with a remote to turn it on/off, adjust the settings, day/night mode, etc. Great subwoofer at about 1/2 to 3/4 the price of an SVS depending on model.
